Hello
Intel replaced my previous NUC for a new similar one due to a faulty display card.
In the new NUC, I have installed the RAM and harddrive that I used in the old NUC, so kept the windows installation.
When I start the NUC, I can load the BIOS screen if I press F2.
If I don't load the bios, I get to Bitlocker. I unlock it with the key and I get the INTEL and the circle "bubble" that turns below it. The Harddrive orange light seem to work and flickers, but then suddenly, the NUC shuts down.
I thought it was the drive, but when I tried to install windows on another drive using an installation USB, it did the same.
Any idea what should be fixed? Or should I send it back to Intel?
Best regards
Which model NUC, both old and new?
Have you tried a clean install?
Have you tried different memory?
Hard disk or SSD? Have you tried different storage?
Thank you for your response:
Which model NUC, both old and new? BXNUC10i5FNH3
Have you tried a clean install? Yes, on another SDD drive
Have you tried different memory? No, I don't have any. I have 16gb
Hard disk or SSD? Have you tried different storage? SDD 1gb Samsung
Surely the SSD must be larger than 1GB, correct?
I would try different memory, from a different manufacturer.
The original SDD and the 16gb RAM worked with the same NUC model. the SDD is 1TB (not GB)
I just removed them and 3 days later I had the new NUC and installed them in.
I unfortunately cannot try with another set of 16gb RAM (don't know anyone who has them around me) and they cost a lot.
The different memory does not have to be 16 GB. If you any compatible sodimm of 4gb or more, just give it a test. Otherwise, an Intel support engineer will have to assist you.
Found a couple of 4 gb ram...still does not work. Bios recognises everything well. But when windows is booting that it fails
It is sounding to me like the replacement NUC that they sent you is a dud. I suggest that you contact ICS and have them replace this unit.
