Intel® NUCs
12328 Discussions
NUC with usb-c docking station for multiple DP monitors
TRobi8
Hi, I am considering buying NUC10i5FNK but I would like to confirm it's compatability with my existing docking station which I use to connect 2 Display Port monitors.
The docking station I have is the StarTech TB3CDK2DPUE which is both USB Type C & Thunderbolt 3.
I think I need to confirm that the USBC-Type C connector on the NUC supports both DP Alt Mode and MST. The tech specs are not 100% clear to me and my situation as I am not looking to daisy chain monitors, but use the docking station.
Thanks in advance,
Tom
n_scott_pearson
Super User Retired Employee
All models in the FN NUC family (Kits and Systems) support DP Alt Mode, MST Hubs and Daisy-Chaining via their USB-C connectors. Only the rear USB-C connector supports Thunderbolt 3, however. Since only a single DP 1.2 output is supplied to each USB-C connector, its bandwidth is shared by all connected monitors. This means that two 4K monitors connected via one USB-C connector will reduce the supportable frequency to 30Hz.
Hope this helps,
