Intel® NUCs
Support for Intel® NUC products
12752 Discussions
NUC10I7FNH with Razer Core / Nvidia Geforce 3060TI
Lagouach
Impossible to connect my Razer Core (3060TI inside) on the Thunderbolt.
The screen display the desktop just 10 seconds and it crash with a windows 10 error message - SYSTEM_THREAD_EXCEPTION_NOT_HANDLED -
I tried to install the latest version of graphic card driver without result.
I tried to install the latest version of the intel Thunderbolt port without result.
Has someone already encountered the problem?
Victor_G_Intel
Hello Lagouach,
Based on the information provided we would like to recommend the following:
-Go to NVIDIA.com to get the latest NVIDIA GPU drivers.
·        Uninstall the current GPU drivers in your system and then perform a clean fresh driver install.
·        Install the latest driver for the NVIDIA GPU card.
-Set the power mode in the NVIDIA control panel to Maximum Performance.
·        To do this, go to 3D Setting > Global Setting > Power Management Setting > Maximum Performance.
-Try To test the unit with a different Thunderbolt cable.
-Set BIOS defaults on the Intel NUC:
·        Press F2 during boot to enter BIOS Setup.
·        Press F9 to load default settings.
·        Press F10 to save and exit BIOS.
-Confirm Windows® 10 is current by using the Windows Update feature.
-In Windows Power & Sleep Settings, turn off PCI Link Power Management:
Steps:
·        Go to Control Panel > Hardware and Sound > Power Options.
·        Select Change Plan Settings.
·        Select Change Advanced Power Settings.
·        Go to PCI Express > Link State Power Management.
·        Set On Battery and Plugged In to Off.
·        Click OK.
-In BIOS try the following steps:
·        Change Power Mode to High Performance.
·        Disable Intel Virtualization Technology for I/O (VT-d) under the Security menu.
·        Disable Advance State Power Management under Power-> Secondary Power Settings.
·        Set Thunderbolt Security Level to Legacy.
-Test the eGPU on a different system (other than an Intel NUC) to ensure it's in working condition.
I look forward to hearing from you.
Victor G.
Victor_G_Intel
Hello Lagouach,
To better assist you please provide the following report to continue with your support request.
Please run the following tool and attach the report generated.
-Intel® System Support Utility (Intel® SSU)
Download link: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
•          Open the application and click on "Scan" to see the system and device information
•          By default, Intel® SSU will take you to the "Summary View".
•          Click on the menu where it says "Summary" to change to "Detailed View".
•          To save your scan, click on "Next", then "Save".
Victor G.
Lagouach
Hello @Victor_G_Intel,
Thank you for your help.
There is the report in attachement.
Victor_G_Intel
Hello Lagouach,
Steps:
·        Click OK.
Victor G.
Victor_G_Intel
Hello Lagouach,
Please let me know if you need further assistance.
Victor G.
Victor_G_Intel
Hello Lagouach,
We have not heard back from you.
If you need any additional information, please submit a new question as this thread will no longer being monitored
Victor G.
