Intel® NUCs
12506 Discussions
NUC10i3FNH "Windows can't installed on this drive."
lumine
Can someone help me with this issue.
Labels (2)
LeonWaksman
1. Could be that the drive failed or is not fully connected. I'm assuming that you have a SSD inserted into M.2 slot. Try to remove the drive from the M.2 slot and then reinsert it again. Verify in BIOS settings Advanced > Devices > SATA and Advanced > Devices > PCI that the M.2 slot is enabled and the SSD is recognized.
2. Boot from your Windows 10 installation USB.
3. Select your language preferences and click/tap on Next
4. Click/tap on Repair your computer at the bottom.
5. Click/tap on Troubleshoot
6. Click/tap on Advanced options.
7. Click on Command Prompt
8. While in Command prompt, execute the following commands (click on Enter after each command):
diskpart
list disk
select disk 0 (I'm assuming that this "0" is assigned to the SSD in M.2 slot)
clean
create partition primary
list partition
select partition X(replace X with the output from the command, most likely 1)
format fs=ntfs quick
9. If you will be able to format this drive try to install Windows.
Leon
