Community
cancel
Showing results for
Search instead for
Did you mean:
ken1943
NUC10i5FNH1 dual channel memory
Jump to solution
One 8 gig stick and in previous computers I always got two equal sticks to run dual channel. Will this NUC run dual channel because I have seen previous posts about problems running dual channel.
Also, I haven't opened the box to see how much of a problem to add a second stick.
Ken
LeonWaksman
Hi @ken1943
This NUC will operate in Dual Channel Memory mode only if you have two memory modules installed. The memory modules should be of the same P/N and even better is you will buy a memory kit - for example this one .
Yes, your NUC is equipped with two memory slots.
Leon
LeonWaksman
Hi @ken1943
Leon
