Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13490 Discussions
NUC10i7FNH - Problem with wireless keyboard and mouse (2,4 GHZ Usb-Stick)
Gruun
I´m new to this forum, to NUC and Win10Pro. Used for more than 20 years apple products. Now changed to PC.
First:
The NUC is a great system. I bought a kit and installed Optane Memory H10 with SSD 32 GB M.2 and 1000 GB Intel, all on one M.2.
I use 32GB DDR4-2666 SO-DIMM (Kit of 2).
Win 10 Pro.
All updates made, including bios and everything Intel offers. Systems works fine!!!
But:
1 big problem. When i use my wireless Jelly Comb Keyboard and Mouse (https://www.amazon.de/gp/product/B07P4DFHP3/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1) the mouse does not work well. When I use any of the offered USB-Ports (or even a USB-C Hub) only the mouse makes problems. And if i use it together with the 2,4GHZ USB-Stick any other Stick (64 GB) the mouse does not work any longer.
It is definitely NOT a problem of the mouse, because tested on other systems like a MacBookPro late 2011 or a Lenovo Duet Chromebook it works fine.
Where is the problem???
Can someone give me an advice?
Thank you.
LeonWaksman
Hi @Gruun
1. The USB WiFi receiver may suffer from EMI interference. Please try to connect this receiver in some distance from the USB 3 port on your NUC. You may use USB some extension cable or connect it to USB HUB
2. FYI, in all my NUC computers I'm using Logitech mouse + keyboard combo (like this one) and I don't have problem with mouse or keyboard.
Leon
