Intel® NUCs
12117 Discussions
NUC11 Stutters and Crashes
lastkey
I've built a new Intel NUC11 Panther Canyon Performance Kit i7-1165G7 Mini PC Barebone Kit RNUC11 a couple of weeks ago but since I got it, I'm having sudden stutters. If PC sleeps it doesn't wake up, rather restarts. I unchecked "Turn on Fast startup" option in "Choose what power buttons do". That has reduced crashes to some extent.
Following are more details about specs:
  • RAM: Kingston 32GB (2x16GB) KF432S20IB1K2/32 Fury Impact 3200MHz DDR4 CL20 SODIMM RAM
  • SSD: Samsung 980 PRO 500GB M.2 2280 PCIe 4.0
Event viewer shows even ID 41 and 6008. What is the reason for these crashes? I ran an extended MEMTEST86 and Windows Memory Diagnostics but no error was found.
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
  <Provider Name="EventLog" />
  <EventID Qualifiers="32768">6008</EventID>
  <Version>0</Version>
  <Level>2</Level>
  <Task>0</Task>
  <Opcode>0</Opcode>
  <Keywords>0x80000000000000</Keywords>
  <TimeCreated SystemTime="2021-09-11T02:42:52.8825451Z" />
  <EventRecordID>1410</EventRecordID>
  <Correlation />
  <Execution ProcessID="0" ThreadID="0" />
  <Channel>System</Channel>
  <Computer>DESKTOP-OJUH5U9</Computer>
  <Security />
  </System>
- <EventData>
  <Data>12:06:44</Data>
  <Data><u+200e>11/<u+200e>09/<u+200e>2021<lt;<u+200e>09//Data09/<u+2>gt;a09/
  a09/<u+<lt;a09/Data /9/<u+20>gt; /9/
   /9/<u+<lt; /9/Data /9/<u+20>gt; /9/
   /9/<u+<lt; /9/Data /9/<u+>gt; /9/73058/9/<u+2<lt;8/9//Data/9/<u+2>gt;a/9/
  a/9/<u+<lt;a/9/Data /9/<u+20>gt; /9/
   /9/<u+<lt; /9/Binary9/<u+20>gt;ry9/E507090006000B000C0006002C00BF02E507090006000B00020006002C00BF02DC0500003C00000001000000DC050000010000001E0000000100000000000000</Binary>
  </EventData>
  </Event>
- <System>
  <Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331c3b3a-2005-44c2-ac5e-77220c37d6b4}" />
  <EventID>41</EventID>
  <Version>8</Version>
  <Level>1</Level>
  <Task>63</Task>
  <Opcode>0</Opcode>
  <Keywords>0x8000400000000002</Keywords>
  <TimeCreated SystemTime="2021-09-11T02:42:44.3428977Z" />
  <EventRecordID>1427</EventRecordID>
  <Correlation />
  <Execution ProcessID="4" ThreadID="8" />
  <Security UserID="S-1-5-18" />
  </System>
- <EventData>
  <Data Name="BugcheckCode">0</Data>
  <Data Name="BugcheckParameter1">0x0</Data>
  <Data Name="BugcheckParameter2">0x0</Data>
  <Data Name="BugcheckParameter3">0x0</Data>
  <Data Name="BugcheckParameter4">0x0</Data>
  <Data Name="SleepInProgress">0</Data>
  <Data Name="PowerButtonTimestamp">0</Data>
  <Data Name="BootAppStatus">0</Data>
  <Data Name="Checkpoint">144</Data>
  <Data Name="ConnectedStandbyInProgress">false</Data>
  <Data Name="SystemSleepTransitionsToOn">5</Data>
  <Data Name="CsEntryScenarioInstanceId">0</Data>
  <Data Name="BugcheckInfoFromEFI">false</Data>
  <Data Name="CheckpointStatus">0</Data>
  <Data Name="CsEntryScenarioInstanceIdV2">0</Data>
  <Data Name="LongPowerButtonPressDetected">false</Data>
  </EventData>
  </Event>
LeonWaksman
Hi @lastkey
You didn't give much information about your system (except for SODIMM and SSD which looks OK). In order to get better information about your system, please download the Intel System Support Utility (SSU). Run the SSU scan (check "Everything") and save the results. The .txt file with the results please attach to your post.
If you didn't do yet, please download the latest BIOS file PA0041.CAP and update your firmware using F7 update method.
Leon
lastkey
Hi Leon,
I've attached the System information file. I already have BIOS version 0041. I checked with Intel® Driver & Support Assistant, and everything is updated. All windows updates are installed as well.
LeonWaksman
Hi @lastkey
Although BIOS is updated to the last version (0041), please check in BIOS the EC Firmware version (should be  03.03.00) and ME Firmware: 15.0.10.1447. Both version numbers are displayed on BIOS Main Screen.
Leon
lastkey
Both are up to date. Please see attached snapshot
lastkey
The System Information file has recorded the restarts but those alerts are not very informative, at least to me.
LeonWaksman
Hi @lastkey
Many similar complains (...to many), I saw in this forum regarding Panther  Canyon NUC. So, could be that is some general problem to fix in BIOS or your NUC need to be replaced.
At this point if you want to exclude problems in Windows,  you may try to Repair Windows with an In-place Upgrade.  Performing this upgrade will replace your current Windows with a new installation, leaving your Data and Applications.
Leon
lastkey
In-place upgrade is a long and lengthy process and we are not sure if that will fix the issue. I’ll open a support ticket.
lastkey
I've opened a support ticket after trying BIOS setting to default, re-seating RAM. The crash still occurred. It's the same theme again. I left the NUC powered on after doing troubleshooting with Intel Support. When I came back after half an hour or so, the NUC was powered off. I found same error in System Report and Event ID 41 and 6008.
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
The previous system shutdown at 20:14:44 on ‎20/‎09/‎2021 was unexpected.
n_scott_pearson
Super User Retired Employee
A significant cause of spontaneous system resets is memory bus lockups. This can be the result of noise on the memory buses (using memory at unsustainable speeds), a failure in the processors memory controllers, a failure in the SODIMM memory controllers or bad memory. Have you tried using a sophisticated tool like MemTest86 to test your memory? No, not that mickey mouse, worthless capability provided in Windows that doesn't even test all memory. You need a good tool and you need to run it for 12-24 hours.
Hope this helps,
lastkey
Yes, I've performed a test with both Windows Diagnostic and MemTest86. MemTest86 ran for around 6 hours and found no errors. I've attached the report here.
lastkey
To provide an update. I've done an In-Place upgrade but still had a crash a few minutes ago with Event ID 41 and 6008. Although I saw something new in the System Information file this time.
The previous system shutdown at 16:43:48 on <u+200e>22/<u+200e>09/<u+200e>2021 was unexpected.
Miniport Microsoft Wi-Fi Direct Virtual Adapter #2, {9f6270fb-6050-4294-b149-07fa869a2b29}, had event Fatal error: The miniport has failed a power transition to operational power
LeonWaksman
Tank you for update. Looks like a hardware problem?
Leon
lastkey
Yes, looks like. I've opened a support ticket and they had asked to do In-upgrade as well so I did it but it didn't help either. I've given them feedback with logs. Let's see but looks like NUC is faulty. Having issues from day one.
lastkey
The unit was replaced under warranty. No issues observed in the new unit so far.
Georgi
I am just building a similar setup (especially the same memory modules).
Did unit replacement resolve your problems permanently?
Are you using exactly the same memory pair also with the new unit?
lastkey
I used the same memory pair and PCI NVME with the new unit and now have no issues. So the problem was in the unit, probably a faulty power unit.
