Intel® NUCs
12298 Discussions
NUC11BTMi9 Network issues on Ubuntu
MatthK
I just bought a Intel NUC11BTMi9 and installed Ubuntu Server 20.04.3 on it. The install worked quite fine and the machine is up and running. I however have two issues.
  1. I installed Virtualbox on it, but when I try to run a guest VM, it can't get a bridget IP address
  2. The Wifi adapter was apparently not recognized and does not work
Do you have any idea on how I can get these two problems solved?
I understand that Ubuntu is not on the list of supported operating systems, but I was still hoping to find a solution. Especially the first problem is really an issue, as I bought it specifically to host a few VM.
Alberto_R_Intel
MatthK, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance on this scenario, we just wanted to confirm a few details about your system:
When did you purchase the Intel® NUC?
You mentioned it is new, did the Virtualbox and the Wifi adapter ever work fine on this same Intel® NUC?
When did the issue start?
Did you make any recent hardware/software changes that might cause this problem?
https://www.intel.com/content/www/us/en/download/18895/26735/intel-system-support-utility-for-the-li...
Albert R.
MatthK
Thank you very much for your reply. Here are the details you have asked for.
  • I bought the NUC two days ago at a local computer shop.
  • As I just bought it two days ago, it never worked before. I did a fresh install of Ubuntu 20.04.3 and then I installed Virtualbox. Once that was up and running, I migrated an existing Virtual Machine from another computer and tried to start it up on the new NUC. But it never got a Bridged Network connection. I have posted about the problem also in the Virtualbox forum, but there was also no solution so far.
  • As it never worked, it started from the beginning
  • No changes made, it is with the fresh install
  • I have that in a home network environment
Below is the SSU report requested.
# SSU Scan Information
Scan Info:
     Version:"1.0.0.0"
     Scan Date:"2021/11/18"
     Scan Time:"10:29:07"
## Scanned Hardware
Computer:
          BaseBoard Manufacturer:"Intel Corporation"
          Bios Mode:"UEFI"
          Bios Version/Date:"DBTGL579.0043.2021.0611.1805,06/11/2021"
          CD or DVD:"Not Available"
          Platform Role:"Linux vs02 5.4.0-90-generic #101-Ubuntu SMP Fri Oct 15 20:00:55 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux"
          Processor:"11th Gen Intel(R) Core(TM) i9-11900KB @ 3.30GHz"
          Serial Number:"G6BT1320079V"
          SMBIOS Version:"3.3.0"
          Sound Cards:"USB-Audio - USB Audio"
          Sound Cards:"00"
          System Manufacturer:"Intel(R) Client Systems"
          System Model:"NUC11BTMi9"
          System Type:"x64-based PC"
          - Display
               - "Intel Corporation Device 9a60 (rev 01) (prog-if 00 [VGA controller])"
                    Adapter RAM:"size=256M"
                    Capabilities:"[40] Vendor Specific Information: Len=0c <?>"
                    Capabilities:"[70] Express Root Complex Integrated Endpoint, MSI 00"
                    Capabilities:"[ac] MSI: Enable- Count=1/1 Maskable+ 64bit-"
                    Capabilities:"[d0] Power Management version 2"
                    Capabilities:"[100] Process Address Space ID (PASID)"
                    Capabilities:"[200] Address Translation Service (ATS)"
                    Capabilities:"[300] Page Request Interface (PRI)"
                    Capabilities:"[320] Single Root I/O Virtualization (SR-IOV)"
                    Caption:"Intel Corporation Device 9a60 (rev 01) (prog-if 00 [VGA controller])"
                    Device ID:"8086:3019"
                    Driver:"Not Available"
                    Driver Path:"Not Available"
                    Driver Provider:"Not Available"
                    Driver Version:"Not Available"
                    Flags:"bus master, fast devsel, latency 0, IRQ 255"
                    I/O Ports:"I/O ports at 3000 [size=64]"
                    Manufacturer:"Intel Corporation [8086]"
                    Power Management Capabilities:"Power Management version 2"
                    Refresh Rate - Current:"Not Available"
                    Resolution:"Not Available"
          - Memory
               Physical Memory (Available):"62039 MB"
               Physical Memory (Installed):"63949 MB"
               Physical Memory (Total):"72141 MB"
               - "Controller0-ChannelA-DIMM0"
                    Capacity:"32 GB"
                    Configured Clock Speed:"Not Available"
                    Configured Voltage:"1.2 V"
                    Data Width:"64 bits"
                    Form Factor:"SODIMM"
                    Interleave Position:"First Position"
                    Locator:"Controller0-ChannelA-DIMM0"
                    Manufacturer:"Kingston"
                    Maximum Voltage:"1.2 V"
                    Minimum Voltage:"1.2 V"
                    Part Number:"905744-062.A00G"
                    Serial Number:"69A6ABB2"
                    Type:"Synchronous"
               - "Controller1-ChannelA-DIMM0"
                    Capacity:"32 GB"
                    Locator:"Controller1-ChannelA-DIMM0"
                    Serial Number:"AF671756"
                    Type:"Synchronous"
          - Motherboard
               Product:"NUC11DBBi9"
               Serial Number:"GEDB128008R1"
               Version:"M17026-302"
          - Networking
               - "Intel Corporation Device 15f2 (rev 03)"
                    Supports auto-negotiation:"Yes"
                    Advertised auto-negotiation:"Yes"
                    Auto-negotiation:"on"
                    Availability:"enp89s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500"
                    Capabilities:"[40] Power Management version 3"
                    Capabilities:"[50] MSI: Enable- Count=1/1 Maskable+ 64bit+"
                    Capabilities:"[70] MSI-X: Enable+ Count=5 Masked-"
                    Capabilities:"[a0] Express Endpoint, MSI 00"
                    Capabilities:"[100] Advanced Error Reporting"
                    Capabilities:"[140] Device Serial Number 1c-69-7a-ff-ff-d0-5e-37"
                    Capabilities:"[1c0] Latency Tolerance Reporting"
                    Capabilities:"[1f0] Precision Time Measurement"
                    Capabilities:"[1e0] L1 PM Substates"
                    Caption:"Not Available"
                    Default IP Gateway:"192.168.7.1"
                    DHCP Enabled:"Yes"
                    DHCP Lease Expires:"Not Available"
                    DHCP Lease Obtained:"Not Available"
                    DHCP Server:"Not Available"
                    Driver:"igc"
                    Driver Path:"/lib/modules/5.4.0-90-generic/kernel/drivers/net/ethernet/intel/igc/igc.ko"
                    Driver Provider:"Intel Corporation, <linux.nics@intel.com>"
                    Driver Version:""
                    Duplex:"Full"
                    Firmware Version:""
                    Interface:"enp89s0"
                    I/O Ports:"Not Available"
                    IP Address:"192.168.7.22"
                    IP Subnet:"255.255.255.0"
                    MAC Address:"1c:69:7a:d0:5e:37"
                    Net Connection ID:"Not Available"
                    Port:"Twisted Pair"
                    Power Management:"Not Available"
                    Speed:"1000Mb/s"
                    Supported link modes:"10baseT/Half 10baseT/Full, 100baseT/Half 100baseT/Full, 1000baseT/Full"
                    Advertised link modes:"10baseT/Half 10baseT/Full, 100baseT/Half 100baseT/Full, 1000baseT/Full"
                    Partner advertised link modes:"Not Available"
          - Operating System
               Boot Device:"/dev/mapper/ubuntu--vg-ubuntu--lv"
               Last Reset:"up 12:06,  1 user,  load average: 0.19, 0.06, 0.01"
               Locale:"en_US"
               OS Manufacturer:"Ubuntu 20.04.3 LTS \n \l"
               OS Name:"Ubuntu 20.04.3 LTS \n \l"
               Page File:"/swap.img"
               Page File Space (Available):"8388604"
               Page File Space (Used):"0"
               Physical Memory (Available):"62035 MB"
               Version:"5.4.0-90-generic GNU/Linux"
               Virtual Memory (Available):"8388604"
               Virtual Memory (Total):"65484468"
          - Processor
               - "11th Gen Intel(R) Core(TM) i9-11900KB @ 3.30GHz"
                    Architecture:"x86_64"
                    Available:"Offline"
                    Byte Order:"Little Endian"
                    Cache Size:"24576 KB"
                    Caption:"11th Gen Intel(R) Core(TM) i9-11900KB @ 3.30GHz"
                    - Characteristics
                         64-bit capable
                         Enhanced Virtualization
                         Execute Protection
                         Hardware Thread
                         Multi-Core
                         Power/Performance Control
                    CPU Speed (Minimum):"1277.105"
                    CPU Speed (Maximum):"12000 MHz"
                    Current Voltage:"0.9 V"
                    External Clock:"100 MHz"
                    Family:"Core i9"
                    - Flags
                         "ACPI (ACPI supported)"
                         "APIC (On-chip APIC hardware supported)"
                         "CLFSH (CLFLUSH instruction supported)"
                         "CMOV (Conditional move instruction supported)"
                         "CX8 (CMPXCHG8 instruction supported)"
                         "DE (Debugging extension)"
                         "DS (Debug store)"
                         "FPU (Floating-point unit on-chip)"
                         "FXSR (FXSAVE and FXSTOR instructions supported)"
                         "HTT (Multi-threading)"
                         "MCA (Machine check architecture)"
                         "MCE (Machine check exception)"
                         "MMX (MMX technology supported)"
                         "MSR (Model specific registers)"
                         "MTRR (Memory type range registers)"
                         "PAE (Physical address extension)"
                         "PAT (Page attribute table)"
                         "PBE (Pending break enabled)"
                         "PGE (Page global enable)"
                         "PSE-36 (36-bit page size extension)"
                         "PSE (Page size extension)"
                         "SEP (Fast system call)"
                         "SSE2 (Streaming SIMD extensions 2)"
                         "SSE (Streaming SIMD extensions)"
                         "SS (Self-snoop)"
                         "TM (Thermal monitor supported)"
                         "TSC (Time stamp counter)"
                         "VME (Virtual mode extension)"
                    ID:"D1 06 08 00 FF FB EB BF"
                    Level 1 Cache:"384 KiB
fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb cat_l2 invpcid_single cdp_l2 ssbd ibrs ibpb stibp ibrs_enhanced tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid rdt_a avx512f avx512dq rdseed adx smap avx512ifma clflushopt clwb intel_pt avx512cd sha_ni avx512bw avx512vl xsaveopt xsavec xgetbv1 xsaves dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp hwp_pkg_req avx512vbmi umip pku ospke avx512_vbmi2 gfni vaes vpclmulqdq avx512_vnni avx512_bitalg avx512_vpopcntdq rdpid movdiri movdir64b avx512_vp2intersect md_clear flush_l1d arch_capabilities"
                    Level 2 Cache:"10 MiB
                    Level 3 Cache:"24 MiB"
                    Load:"load average: 0.19, 0.06, 0.01"
                    Manufacturer:"Intel(R) Corporation"
                    Model:"141"
                    Name:"11th Gen Intel(R) Core(TM) i9-11900KB @ 3.30GHz"
                    Number of Cores:"8"
                    Number of Cores - Enabled:"8"
                    Part Number:"To Be Filled By O.E.M."
                    Socket Designation:"U3E1"
                    Status:"Populated, Enabled"
                    Version:"11th Gen Intel(R) Core(TM) i9-11900KB @ 3.30GHz"
                    Voltage:"0.9 V"
                    Virtualization:"Not Available"
          - Storage
Alberto_R_Intel
MatthK, You are very welcome, thank you very much for providing that information and the SSU report.
"I understand that Ubuntu is not on the list of supported operating systems", and for that reason, all the drivers that we have available on our official website were tested and validated Windows* as operating system:
https://www.intel.com/content/www/us/en/search.html?ws=idsa-suggested#q=nuc11btmi9&t=Downloads&layou...
Based on the information shown in the document, as you mentioned, the wireless card is not being recognized, and also we can see that the BIOS version currently installed is 0043.
So, first, we can try a BIOS update to the latest version 0050 following the instructions in the links below and then test the iIntel® NUC to confirm if the problem with the wireless card gets fixed, we suggest to use the F7 method. After the update, please check the BIOS under "Onboard Devices" and check if the WLAN option is checked and if the wireless card is recognized in there:
https://www.intel.com/content/www/us/en/download/646323/bios-update-dbtgl579.html?wapkw=nuc11btmi9
https://downloadmirror.intel.com/647472/NUC-AptioV-UEFI-Firmware-BIOS-Update-Readme.pdf
Here you can see additional suggestions on this topic:
https://www.intel.com/content/www/us/en/support/articles/000031666/intel-nuc.html
By any chance, do you have the option to use Windows on the Intel® NUC? This is basically the latest troubleshooting step we recommend, if you do not have that opportunity that is no problem, we just wanted to confirm if the reason why the wireless card is not detected is because the OS is not fully supported by the Intel® NUC or if there is a hardware problem with the machine in which case a replacement will be needed. If the BIOS detects the wireless card then in theory it should be working fine.
In reference to the problem with the WM, even though you have already contacted them, our best recommendation is to keep checking with Virtualbox support for further assistance on this subject:
https://www.virtualbox.org/wiki/Community
Or you can also get in contact directly with Ubuntu Support to check if they have additional suggestions on this matter or with the wireless card not being detected by the OS:
https://www.intel.com/content/www/us/en/support/topics/linux-osv.html
Albert R.
Alberto_R_Intel
Hello MatthK, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
Alberto_R_Intel
Hello MatthK, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
