I have a new NUC11BTMi9. It was professionally assembled with a graphics card. It was working fine until the Intel updater said there was a BIOS update. I ran the BIOS update.
The update ran normally, apparently to completion, but the system will not boot up after the update. The system powers on and then a black screen appears (HDMI monitor connected to the compute module) with a solid underscore and nothing else.
I've tried everything I can think of. I've removed the graphics card, tried to hold the power button for various numbers of seconds, removed the BIOS security jumper, attached a USB drive with the recovery BIOS, and so on.
Nothing I do makes any difference. I always get the same behavior -- the system powers up and a few seconds later I get a black screen with a thick, solid white underscore. The power light stays on solid white. It doesn't matter what devices are or aren't connected. If I attach a keyboard, it is never initialized, so I can't press any keys.
Any suggestions?
- Tags:
- Bios Update
- brick
Hello DavidSchwartz,
Thank you for posting on the Intel
- Short video of the issue.
- How did you perform the BIOS update?
Josue O.
I tried to shoot a video, but there's nothing to see. Everything is black and all you can see are reflections that go in and out of focus off the black surfaces.
I apply power, the white power light comes on and stays solid. After a few seconds, the screen goes completely black except for a large white underscore (solid) in the upper left corner.
Nothing else happens. No USB devices are ever initialized. No other lights come on.
I just installed the BIOS update from the Intel Windows tool. It rebooted, ran the BIOS updater, and then it died.
I also started having the issue on the 16th so I’ve had it working only a couple of weeks.
Intel support had me try the recovery boot which didn’t succeed, and the vendor is asking me to return it.
It’s a shame, too, since it was working fine until then.
Makes me wonder if there’s an issue with a third party branded BIOS — the only change I’m aware of is the third party’s name in there.
Thank you for the information provided, as VictorMC, please try performing a BIOS recovery using the "Security Jumper" method, you can find the instructions on the following link:
https://www.intel.com/content/www/us/en/support/articles/000033291/intel-nuc.html
Remember to use the latest BIOS available, you can download it from our download center:
https://www.intel.com/content/www/us/en/download/646323/bios-update-dbtgl579.html
Let me know if the issue persists after the recovery.
Josue O.
As I said, "I've tried everything I can think of. I've removed the graphics card, tried to hold the power button for various numbers of seconds, removed the BIOS security jumper, attached a USB drive with the recovery BIOS, and so on."
I'll try it one more time to make absolutely sure I followed the process.
Sure, please let us know the results of the troubleshooting.
Josue O.
I tried it. There was no difference. I don't think it's even looking at the USB ports because when I connect a keyboard, I don't see it get initialized.
Is there anything else I can try or is it RMA time? And, if so, should I send it back to Intel or to the system builder?
In this case and based on the troubleshooting steps performed, the next step would be to replace the unit. You can replace it with the place of purchase if it was bought 30 days ago or less.
Also, you can get in contact with us directly and check the RMA options. Use the link based on your location:
1. US, Canada:
2. Europe, Middle East, and Africa:
3. Asia-Pacific:
4. Latin America:
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
