Hello - recently purchased a NUC11BTMi9 and built it up (Win 11 Home). Everything works fine except the front panel I/O sockets, not sure why. I have checked device manager and no warnings, all hardware has been identified with drivers installed... im worried I may have a faulty unit. Can anyone advise on how to resolve this issue?
I have been using the rear USB ports just fine...
- Tags:
- Front
- NUC11BTMi9
- usb
The typical cause for this issue is that the cable that connects the Front Panel I/O devices to the NUC 11 Extreme Compute Element is not plugged in properly. This cable plugs into the Internal USB 3.1 Gen 2 Type-C 20pin (Key B) header on this Compute Element. This header is Item B in Figure 12, NUC11 Extreme Compute Element Headers and Connectors, on page 24 of document Intel NUC 11 Extreme Kit/Compute Element Product Specification.
Hope this helps,
Hope this helps,
thankyou for your help - i will dig around in there and wiggle it
You were 100% correct - I should have known... my fat fingers. All working now, thankyou Sir!
