I'm getting 0xc1900101 error during installation Seems like it might be a driver issue but everything is up to date except;
Installs Intel® Serial IO Driver for the 11th Generation Intel® NUC Products.
30.100.2129.8Release date:
January 11, 2022Size:
2.18 MB
Hello rhhays,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® NUC 11 Performance kit - NUC11PAHi7.
1. Are you upgrading from Windows 10 to Windows 11?
2. Are performing a fresh installation of Windows 11?
3. Have you tried the steps from the following article?
Deivid A.
I'm upgrading from Windows 10 Pro version 21H1 - build 19043.1645
Looks like the link article is for a fresh install so I do see that I can do that.
Hello rhhays,
I am glad to know that will try a fresh installation of Windows 11. Please let me know if the issue persists or if you were able to install Windows 11 successfully.
Deivid A.
What else can I try?
Hello rhhays,
I understand your situation. In this case, you can try to back up your files and perform the fresh installation or you can get in contact with Microsoft to confirm the proper steps to upgrade to Windows 11 from Windows 10.
Deivid A.
Hello rhhays,
I reviewed your post, please let me know if the issue was resolved, if not, do not hesitate, just reply back.
Deivid A.
Thanks for checking.
Richard
Hello rhhays,
I am sorry to know that the issue continues. I will check this internally to check if we have any further instructions for you. As soon as I have any information I will let you know.
Deivid A.
Hello rhhays,
Based on the research performed, even though the Intel® NUC 11 Performance kit - NUC11PAHi7 is compatible with Windows 11 for upgrade issues the support is provided by Microsoft.
I recommend you keep checking with Microsoft for support.
Deivid A.
Realtek* High Definition Audio Driver for Windows® 10 64-bit and Windows® 11 for the 11th Generation Intel® NUC11PA[x]
