Intel® NUCs
Support for Intel® NUC products
12755 Discussions
NUC11PAHi5, temperature unit not displayed correctly in BIOS after upgrade to v0042
argh0815
Upgraded my BIOS today, now the temperature unit in the BIOS Cooling section is not displayed correctly, used to be °C, now it's a placeholder sort of thing, screenshot attached. Downgrade to v0041 would fix it, however the EC firmware got updated as well with v0042 and downgrade BIOS doesn't downgrade EC firmware.
Could this cosmetic error be fixed in the next BIOS version please or any advice how I could force EC firmware to be downgraded as well when downgrading BIOS?
Ronny_G_Intel
Community Manager
Hi argh0815 and everyone,
Thanks for reporting, this cosmetic issue will be addressed by the next BIOS version, I still don't have a release date for it so please stay tuned for this update.
Ronny G
JosueO_Intel
Hello argh0815,
Thank you for posting on the Intel communities. In order to have a better understanding of the issue, please share with us the following information:
  1. Which method did you use to update the BIOS?
  2. Download and install the Intel System Support Utility (Intel SSU):
    1. https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
    2. Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View".
    3. Click on "Next", save the report and attach it to your response.
Josue O.
argh0815
1. F7 method to upgrade to v0042. To downgrade to v0041 I tried Express BIOS update, F7 BIOS update and UEFI BIOS update, but none of them would downgrade the EC firmware to 03.03.00.
2. Attached.
JosueO_Intel
Hello argh0815,
Josue O.
Ronny_G_Intel
Community Manager
Ronny G
David_G_Intel
Let us know if you have any questions.
David G.
argh0815
Yes thanks, will update the BIOS once it's available.
David_G_Intel
We're glad to know the information helped. Please keep in mind that this thread will no longer be monitored by Intel. Thank you for your understanding.
David G
