I have a NUC11PAHi7 running Windows 10 20H2. Everything was fine, but out of nowhere I have the following odd issue:
When the PC is on, the Power Led is Blinking Blue. That indicates it's in Modern Standby. But, obviously it is not in any standby when it is on.
I can work around this by going into the Bios and changing the LED settings for Modern Standby. I.e. I can just turn it to Solid.
But, I shouldn't have to do that - and it wasn't like that before either. It's like something bugged and now the NUC for whatever reason thinks it's in Modern Standby when it is on.
I tried playing around in the BIOS and also NUC management Studio in Windows, but can't find a way to set Modern Standby to disabled.
It also blinks when I am in the BIOS (so not just in Windows).
Like I said: this popped out of nowhere - i.e. I didn't change any BIOS settings or Windows Power Plan settings.
I have Deep Sleep S4/S5 turned Off in the Bios - if that is related. But it was off before this started.
Hi @Jaap7
1. I would start from resetting BIOS to default settings (F9, F10). FYI, in NUC PA, the Modern Standby is the only possible Sleep Mode.
2. In order to get better information about your system, please download the Intel System Support Utility (SSU). Run the SSU scan and save the results. The .txt file with the results please attach to your post.
Leon
Hi Leon,
Thank you for your reply. I'll wait with the BIOS reset until a bit later. But attached my log from SSU.
Cheers,
Jaap
Hello Jaap7,
1. Have you tried the BIOS recovery? If you have not, here the steps:
- Steps: https://downloadmirror.intel.com/30328/eng/NUC-AptioV-UEFI-Firmware-BIOS-Update-Readme.pdf
- File: https://downloadcenter.intel.com/download/30328/BIOS-Update-PATGL357-
2. Have you tried loading BIOS to default?
3. When and how did you noticed the issue? Ex: after a BIOS update, after a system update.
Deivid A.
Can you describe which of these steps exactly you are having difficulty with.
https://www.intel.com/content/www/us/en/support/articles/000023554/intel-nuc/intel-nuc-mini-pcs.html
Hello Jaap7,
Were you able to check my previous post and try the steps? Please let me know if you need more assistance.
Deivid A.
Hello Jaap7,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
