Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13508 Discussions
NUC11PAHi7 does not perform Suspend-to-RAM
Eling
After upgrading BIOS from 0046 to 0050, NUC11PAHi7 stopped Suspend-to-RAM https://www.kernel.org/doc/html/v4.18/admin-guide/pm/sleep-states.html#suspend-to-ram . Moreover, after such an attempt, it stops turning on until BIOS is reset in the workshop. There was no such problem with version 0046.
Should I downgrade to 0046 version or wait for the new version to fix the problem?
Labels (2)
DeividA_Intel
Hello Eling,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® NUC 11 Performance kit - NUC11PAHi7.
1. What is the operating system installed as well as the version and kernel?
2. Have you made any changes to the BIOS?
3. Is this issue present with Windows 10 or Windows 11?
Bear in mind that due to security reasons, it is not possible to downgrade the BIOS version.
Deivid A.
DeividA_Intel
Hello Eling,
After checking your thread, I would like to know if you need further assistance.
If so, please let me know.
Deivid A.
Eling
I have done several linux tests:
  1. I tried Clear Linux build 38560 (Linux clr 6.2.6-1290.native) with safe settings of the BIOS (F9).
    1. It goes to Suspend-to-RAM but does not wake up. The system restarted.
    2. The menu suspend option works, but a fan continues to run.
  2. I also tried Qubes OS 4.1.2 (Linux dom0 5.15.94-1.qubes.fc32.x86_64). None of the suspend options work here.
Can't say anything about Windows OS. I don't have such systems.
grov
it happens exactly the same (no suspension to ram after BIOS update version 50) on my NUC 11 PAHi5 with Windows 11 22H2.
no settings changes. only new BIOS update
it worked perfectly before
I hope there will be a further BIOS update to fix this
DeividA_Intel
Hello Eling,
Thanks for the confirmation. Before we continue further, I would like you to try a BIOS recovery as a test:
Driver: https://www.intel.com/content/www/us/en/download/19694/bios-update-patgl357.html
Steps (BIOS Recovery by the Power Button Menu): https://downloadmirror.intel.com/766623/NUC-AptioV-UEFI-Firmware-BIOS-Update-Readme.pdf
Deivid A.
Eling
Hello Deivid,
Unfortunately, I was already in a situation where my NUC, after updating, stopped responding to the power button. None of the recipes given in https://downloadmirror.intel.com/766623/NUC-AptioV-UEFI-Firmware-BIOS-Update-Readme.pdf helped, including "BIOS Recovery by the Security Jumper". I had to go to a repair shop to have it repaired. Wouldn't want to be in that situation again.
Is there a reliable way to recover the BIOS at home if a NUC won't turn on?
DeividA_Intel
Hello Eling,
Thank you for the information provided
I understand that do not feel comfortable performing a BIOS ec0overy. I will proceed to check the issue internally and post back soon with more details.
Deivid A.
DeividA_Intel
Hello Eling,
Thanks for your patience. In this case, there is a patch for the (Sleep mode) has a Patch on Windows:
Patch for a Modern Standby LAN Issue on Intel® NUC 11th & 12th Generation Products:
Since Linux is not a validated operating system for this NUC, this feature may not work properly.
Here you can check the list of compatible operating systems for the Intel NUCs:
Deivid A.
DeividA_Intel
Hello Eling,
As the last recommendation, try to get in contact with your Linux distributor to get further support and drivers for your operating system.
I will proceed to close this thread, however, you can open a new one in case you need further support or if you face any issues with our products.
Deivid A.
Eling
Thanks Deivid,
Given that the distributor of Clear Linux is Intel Corporation, can you ask if this problem is known and report the results?
