Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13488 Discussions
NUC11PHBi7 software update Intel Ethernet (LAN) Network driver update fails
toddbud
The
Intel® Driver & Support Assistant
reports
1 software update available
Intel® Ethernet (LAN) Network Connection Driver for the 11th Generation NUC Products for Windows® 10 64-bit and Windows* 11.
When I press install, Windows asks if I want the app to change this device.  I press yes.  It goes back to the windows screen, the browser refreshes, and voila, the same software update is available.
Any ideas, the notification is driving me crazy!
AlHill
Tell IDSA to ignore the update.
[Waiting for Windows 12]
toddbud
Thanks, I like having the notifications to remind me to keep drivers up to date, but I did go to the settings and made it a silent notification.
DeividA_Intel
Hello toddbud,
Thank you for posting on the Intel® communities. I understand you are having issues with the Intel® Driver & Support Assistant (Intel® DSA).
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
2. Can you take a picture of the notification from Intel® Driver & Support Assistant (Intel® DSA)?
3. Which browser are you using?
4. When did you notice the issue?
5. Have you tried to install manually the driver?
6. What is the version that Intel® Driver & Support Assistant (Intel® DSA) is asking you to update to?
Deivid A.
toddbud
  • See Attached
When you press install, it goes through some op sys motions like asking: "Do you want to allow this app to make changes...." then the browser refreshes back to the same notification.
Chrome
A few weeks ago.
Yes, downloaded LAN-Win10_Win11-1.0.2.14.zip and installed it on 2022-02-18.  Current Driver Version:
Intel DSA:
LAN DRIVER:
Description: This download record installs Intel® Ethernet (LAN) Network Connection Driver for the 11th Generation NUC Products for Windows® 10 64-bit and Windows 11*.
Version: 1.0.2.14
Release date: January 9, 2021
DeividA_Intel
Hello toddbud,
Thanks for all the information provided. Before we continue further, I would appreciate if you try the following first:
1. Uninstall the existing Intel® Driver & Support Assistant (Intel® DSA) tool and then reinstall it:
2. Try with a different browser.
3. Clear the browser cache and close the browser.
4. Try to install the driver manually:
Please let me know if the issue persists.
Deivid A.
toddbud
1. I unstalled the DSA using DSAUninstaller.exe from the link you supplied.  I have attached the log file below.
2. I installed the DSA from the link you supplied.  I have attached the log files below.
3. I ran the DSA and tried to install the driver.  This did not fix the problem, when you run DSA again you get:
4. If you read my previous detailed message you would have seen that I already tried installing manually, and that didn't work, but to satisfy your curiosity I tried again. As you can see that did not work, the driver version is still 1.0.2.6, not 1.0.2.14:
and the DSA still indicates the need to update the driver:
I hope this helps....
toddbud
PS I tried clearing browser cache and I tried it with both Edge and Chrome browsers.
DeividA_Intel
Hello toddbud,
Thank you for the information provided
Deivid A.
Ronny_G_Intel
Community Manager
Hi everyone,
I really apologize for the inconvenience, we found that the Intel® Driver & Support Assistant (IDSA) version value was set incorrectly in our internal tool. We made the update, resubmitted it, and it should be working correctly in a few hours (the time it takes for the servers to replicate the new changes).
Please try it again in 24hrs and let me know if you still see issues when running the IDSA scanning.
Ronny G
toddbud
It is still not working. The same thing happens.  See my previous post:
calzon65
The problem is still happening for me on an 11TNKi7.
I also followed Scott Pearson's instructions for manually updating the driver.  The update worked initially (yesterday I confirmed in device manager the new driver version 1.0.2.14 was installed) and ISDA said I did not need any driver updates, but when I checked today after a reboot, my LAN driver was back to version 1.0.2.6 and ISDA is saying I need to update the LAN driver again.
I ran IDSA and its the same garbage again ... driver downloads, I click Install and nothing.
You guys have a total mess on your hands, how about fixing this. Don't you see all the posts from customers.  Think of the thousands of customers who don't post and are wasting countless hours trying to sort through why IDSA is not working with this LAN update.
DeividA_Intel
Hello toddbud,
I am sorry to know that the issue persists. I will check this behavior and let you know if we have any progress on this matter.
Thanks for your comprehension.
Deivid A.
Ronny_G_Intel
Community Manager
Hi everyone,
This issue has been really difficult to resolve and I have to apologize for the delayed responses and recommendations that may not have resolved this situation for everyone.
Please remove the LAN driver (including driver files) and reboot the system, Windows* should immediately update the driver and when you run IDSA, it should report that the system software is up to date.
Note: I would also recommend that you remove and reinstall IDSA, it will refresh its metadata e.g. will remove old alerts such as "This system is not compatible with Intel ARC*".
Ronny G
toddbud
That worked for me.  Thanks, a lot Ronny G!
DeividA_Intel
Hello toddbud,
I am so glad to know that you were able to fix the issue by following the steps provided. I will proceed to close this thread since the issue got solved, however, if you encounter any other issues do not hesitate to open a new thread to get proper support.
Thanks for your time.
Deivid A.
