Intel® NUCs
Support for Intel® NUC products
12746 Discussions
NUC11PHi7 - HDR will not turn on for 4k 60hz, only 30hz
ErikX
Brand new NUC where I cant watch 4k 60hz video content as the screen go black and everything freezes and I have to shut the computer down holding the power button. No issue in 4k 30hz or 4k 60hz without HDR. Windows doesnt allow me to toggle "Use HDR" in Windows HD color setting when in 4k 60hz. When I push it it just jumps back to "Off". Microsoft say to contact the manufacturer as this is due to the graphics drivers. The TV that is connected support 4k 60hz HDR and has shown this with other NUCs connected with same cable setup (and other) and different HDMI inputs.
Intel® Driver & Support Assistant say that all drivers and softwares are up to date and I have downloaded Nvidia GeForce Experience that confirm I have the latest "studio driver".
Sad to have spent more than double my initial budget and still have issues with my NUC. Hope someone can help me with suggestions to get this to work.
System Information
Operating System: Windows 10 Pro 64-bit (10.0, Build 19043) (19041.vb_release.191206-1406)
System Manufacturer: Intel(R) Client Systems
System Model: NUC11PHi7
BIOS: PHTGL579.0065.2021.1014.1705 (type: UEFI)
Processor: 11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz (8 CPUs), ~2.8GHz
Memory: 32768MB RAM
Available OS Memory: 32434MB RAM
Page File: 7567MB used, 29731MB available
Microsoft Graphics Hybrid: Supported
Display Devices
Card name: NVIDIA GeForce RTX 2060
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 22197 MB
Dedicated Memory: 5980 MB
Shared Memory: 16217 MB
Current Mode: 3840 x 2160 (32 bit) (60Hz)
HDR Support: Supported
Display Topology: Internal
Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
Color Primaries: Red(0.639648,0.344727), Green(0.291016,0.634766), Blue(0.163086,0.092773), White Point(0.288086,0.295898)
Display Luminance: Min Luminance = 0.010000, Max Luminance = 1499.000000, MaxFullFrameLuminance = 799.000000
Monitor Name: Generic PnP Monitor
Monitor Model: Panasonic-TV
Monitor Id: MEIA296
Native Mode: 3840 x 2160(p) (30.000Hz)
Output Type: HDMI
Monitor Capabilities: HDR Supported (BT2020RGB BT2020YCC Eotf2084Supported )
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
Advanced Color: AdvancedColorSupported
Driver File Version: 30.00.0014.7247 (English)
Driver Version: 30.0.14.7247
