Has anyone successfully installed the ethernet driver.
The download page https://downloadcenter.intel.com/download/30137/Intel-Ethernet-LAN-Network-Connection-Driver-for-NUC...
Provide one that doesn't work.
The Intel Driver and support Asistant also doesn't work.
Any hints?
Hello patc
Thank you for posting on the Intel️® communities. Please share with us more information on the issue, troubleshooting steps you tried and Intel® System Support Utility (Intel® SSU) results
- Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
- Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
- Click on the menu where it says "Summary" to change to "Detailed View".
- To save your scan, click on "Next", then "Save".
David G
Attached SSU output. It shows no LAN driver (Wireless is o.k.)
Using the Ïntel Driver and Support Assistant"shows the driver is Missing. Click the install and it tries to run , them comes back and says the driver is missing
Thank you for the information provided, the operating system is not up to date. Please run all the Windows updates, re-install the Intel® DSA and if you still can't install the LAN driver please follow the manual installation:
David G
David G.
David G.
