The technical document for the NUC11TNB states (Section 4.1.1) the board has a combined SATA+POWER port in the form of a ZIF connector (Described as ZIF FPC/FFC with lock)
How does one connect this to a SATA SSD? Is there a breakout cable to convert the ZIF to SATA and POWER?
Russell
The cable is only supplied when you purchase the 'taller' H chassis, which also provides the drive bay for 2.5" SSD/SSHD/HDD. If you have purchased the 'shorter' K chassis or you have purchased bare board, no cable assembly is supplied. GORITE produces and MicroSATACables.com sells a cable assembly that can be used.
Note that connector only provides sufficient power for 2.5" media. You cannot use 3.5" or 5" media.
Hope this helps,
Hope this helps,
