After moving from a 8th Gen NUC to this 11th Gen NUC (NUC11TNHI7 ) & installing Win10 I am unable to see the Samsung EVO 850 which in fitted in to the 2.5" drive bay.
Have checked the BIOS 7 the Sata port is Open?.
Any suggestions would be appreciatted.
Thanks, Paul.
Hello Pjkiwi,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® NUC 11 Pro Kit NUC11TNHi7.
1. Have you updated the BIOS?
2. Have you tested a different SSD?
3. Have you loaded the BIOS settings to default?
4. Have you updated the SSD firmware? You may need to contact the SSD manufacturer for steps.
Deivid A.
Hello Pjkiwi,
Deivid A.
Hi Deivid,
Hello Pjkiwi,
Thanks for your confirmation. I am glad to know that you were able to fix the issue by replacing the SSD, this issue may be related to a compatibility issue with the EVO860 SSD.
I will proceed to close this thread, however, you can open a new one in case you need further assistance or if you face any issues with our products.
Deivid A.
