Intel® NUCs
Assistance in Intel® NUC products
13310 Discussions
NUC11TNHi3 SATA Drivers?
pioux
Hello. Long-time lurker, first time poster
I picked up an NUC11TNHi3 and am trying to install Windows 10.
Installing a fresh copy of Windows and I have created the USB install disk with whatever the latest version the windows media creator has.
The problem I am running into is that windows set up does not detect the SATA drive that I have in there.
The BIOS sees the drive.
I downloaded the chipset driver on the product page... but it did not have the SATA controller driver.
I did try every single one that was available and none worked.
Does anyone have the SATA driver for this so Windows can detect the drive and I can continue installing windows?
Thank you!
Jean_Intel
Hello pioux,
The issue seems to be related to the Windows installer since the drive is detected by the BIOS. I found information about this issue on a Microsoft forum. You should take a look at the information provided and try their suggestions to confirm if it works for you:
https://answers.microsoft.com/en-us/windows/forum/all/windows-10-clean-install-unable-to-detect-hard/83911a55-c82d-42b6-8369-3d6369fedf5f
Let me know if your issue persists after trying the suggestions gathered on the Microsoft support forum.
However, if you want, you can also try the following:
  • Try another SATA Drive.
  • Try another Windows installer.
Jean O.
Jean_Intel
Hello pioux,
I hope you are doing fine.
Jean O.
Jean_Intel
Hello pioux,
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
