I bought a NUC11TNHi5, but I can't access the AMT menu. And I've updated the BIOS to the current version and tried CTRL-P numerous times, but still can't get to the AMT menu. Can you help me? thank you!
xzfxzf1978, Thank you for posting in the Intel® Communities Support.
Based on the information shown on the TPS (Technical Product Specification), it says "Intel® AMT/vPro support on Core i5 vPro and Core i7 vPro SKUs only" page 15:
https://www.intel.com/content/dam/support/us/en/documents/intel-nuc/NUC11TN_TechProdSpec.pdf
The Intel® processor on your device is Intel® Core™ i5-1135G7 and I cannot confirm if it supports Vpro:
So, we will do further research on this matter, either for us to try to provide a possible solution for this scenario or to point you in the right direction for support. As soon as I get any updates, I will post all the details on this thread.
Albert R.
I responded to this version of the query. As I said, I do not believe that the NUC11TNHi5 supports vPro.
Hello xzfxzf1978, I just received an update on this matter.
After reviewing the case, we can confirm that the Intel® NUC 11 Pro Kit NUC11TNHi5 does not support Vpro technology. In the following link you will find the units that support this feature:
Thank you very much, N. Scott Pearson.
Albert R.
