I don't have NUC11TNKi5, however, checking the specification, I understand that the second M.2 slot is PCIe x 1 only, designed for SATA drive.
Leon
Thank you for your interest.
So as a result, is the SN520 SSD M.2 SSD used?
To work correctly the NVMe SSD need to have four PCIe lines, while the M.2 B slot in your NUC have only one. So, the SN520 is not suitable for this slot. Intel tested three M.2 SATA SSDs, for this slot. Only three SSD where tested by Intel, but additional SATA SSD with M.2 form factors Type 2242 may be installed in this slot, however where not validated by Intel.
Leon
I noticed the list of compatible components on the Intel website seems outdated. Then when Intel tested something, it was always the most expensive version such as a business might buy. I didn't think I would ever figure out what economical components would fit in my NUC, but then I realized if one goes to the component manufacturer's website, they are generally going to tell you which computers their components will work in. Also, it helps to stick to the same brand that Intel tested even if it's not the same model component. I have read in other posts that NUCs are particularly sensitive as to what components they will accept, so if you don't at least see the Western Digital brand on the list of compatible components for anything, you don't want to use Western Digital!
I bought my first NUC in 2016. Since I never had any problems with it, so I bought again, only much better - NUC11TNKi7.
And how disappointed I am that the second socket is not NVMe but only M.2 2242 B-Key.
As you know, the choice of this type SSD is small and bet all of them - low capacity (512Gb max) and speed (550 mbps).
I don’t understand why "Intel" did that.
Intel does not throw away a fortune purchasing peripherals to test with the NUCs. Considering sales volumes, doing so would significantly increase the price of validation and thus the overall price of the NUCs. If they do not get samples sent to them, they do not get tested; it's that simple.
I think the point here is that why Intel did not allow M2 2242 port be NVMe compatible but only SATA???
I don't think that was just a question of purchasing peripherals for testing but design choice to drop NVMe support from 2242.
There are very little choices for 2242 SATA models with any known brand and ZERO larger than 512GB! Practically Transcend 430S 512GB is the only considerable choice. Sure I've seen those larger ones you listed selling, but they all are "never heard" brands for me with almost zero reviews. I value my data way too much for taking chances with SSD I'm not sure is reliable. I guess just using external SSD connected all the time would be even better choice, but even there are not much ones that are durable and suitable for constant use. I have got Samsung T5 myself but that is terrible in terms of SSD life because wear level count increased by 1% every 250GB, so only 25TB total life based on that (even smallest internal M2 SSD's have 150TB or more). Not sure if there are better ones (durable) in other models or brands for external ones...
Not sure where you're looking, but there are definitely drives larger that 512GB available. Here are some examples,
1TB: https://www.amazon.com/dp/B099WBG6ZD
1TB: https://www.amazon.com/dp/B07TB6BLS9
1TB: https://www.amazon.com/dp/B086MGPQF7
1TB: https://www.amazon.com/dp/B0834L2NF6
1TB: https://www.newegg.com/p/0D9-00HY-00070
1TB: https://www.newegg.com/p/2RC-05UX-00009
1TB: https://www.newegg.com/p/0D9-000D-00140
2TB: https://www.amazon.com/dp/B07ZF6K1Y6
2TB: https://www.amazon.com/dp/B08FT6WT25
2TB: https://www.newegg.com/p/0D9-000D-00141
Hope this helps,
