IDSA indicates I have a LAN driver update (ver 1.1.3.34 released February 8, 2023).
IDSA fails to install the update, so I downloaded the update manually. When I unpack the update, I see there is no .exe file. There are four files in the zip, e3fmsg.dll, e2f.sys, e2f.inf, and e2f.cat.
Could anyone tell me how I am to install this LAN driver update?
Right mouse click on the .inf file and then left click on "Install".
Leon
Leon,
Thank you for taking the time to respond.
As you suggested, I right clicked on the .inf file, but I received no confirmation anything installed, and when I re-run IDSA to verify I have the latest LAN driver, I still get a messaging saying I need to install the LAN driver update. Of course, when I click Install via IDSA, I continue to get an error message that the installation failed.
I've found in the roughly 2 years using IDSA, it only reliability works about 90% of the time. This is not the first time IDSA has prompted me to install a driver but the installation fails. When this happens, I usually manually download the new driver and upgrade manually.
So after your suggestion it dawned on me, try the old-school approach via Device Manager. So I launched Device Manager, selected the LAN (Ethernet) device, selected the Driver tab then ran Updated Driver pointing to the folder of the LAN driver I downloaded, and it upgrade to the current driver v1.1.3.34.
It's a shame Intel continues to produce a substandard update solution through IDSA. Never-the-less, I sincerely appreciate your suggestion as it got me thinking and I ultimately updated my LAN driver ... without any help from the less than reliable IDSA.
Try to reinstall the IDSA:
1. Uninstall the currently installed IDSA, using IDSA Uninstaller.
2. Download and install IDSA again.
Leon
