Intel® NUCs
12513 Discussions
NUC12DCMi9 NVME Gen4 SSD perf degrade after 0052 BIOS update
Jay_W
System: NUC12DCMi9, 2 x 32GB RAM, Samsung 980 PRO NVME Gen4
The SSD is installed in M.2 slot 1 (CPU attached).
On BIOS version 0046, the SSD benchmark can easily hit 5,000MB+/s seq read and write.
After BIOS upgraded to version 0052, the same benchmark result dropped to 1,800MB/s seq read and write.
I tried to move the SSD to M.2 slot 2, got the same results.
I then tried to move the SSD to M.2 slot 3, then it hit 5,000MB+/s again with 0052 BIOS.
Reverted BIOS version to 0046, slot 1/2 perf back to normal.
SATA controller disabled in BIOS.
VMD disabled in BIOS.
During benchmark runs the SSD temperature has been stable ~60°C.
Is this a known issue, or do I need to change any settings after 0052 upgrade?
Thanks!
Jean_Intel
Hello @Jay_W,
I will be contacting you via email with a suggestion that may solve the issue.
Jean O.
Jean_Intel
Hello Jay_W,
To have a better understanding of your issue, please provide me with the following:
  • What is the benchmark program you are using?
  • What is the make and model of the SSD with issues?
  • Are you able to try another SSD on the M.2 slots where you experience an issue?
  • Does the issue affect the performance under normal use? Remember, when running benchmarks, the devices tested are running under an artificial workload.
  • Create a report using the Intel System Support Utility (Intel SSU)
Jean O.
Jay_W
    Samsung Magician 7.1.1
    CrystalDiskMark 8.0.4
    - Results from both programs are similar.
    Samsung 980 PRO PCIe 4.0 NVMe M.2 SSD (500GB)
    Today I added another 980 PRO (same model but 2TB size) to M.2 slot 2, same results.
    Yes, large file (20GB+) copy operations are noticeably slower with 0052 BIOS.
Jean_Intel
Hello Jay_W,
Jean O.
Jean_Intel
Hello Jay_W,
To continue with my investigation, and since you were able to downgrade the BIOS to the previous version, please provide me with screenshots of the benchmarks with each BIOS version.
Jean O.
Jay_W
Screenshots with both Samsung Magician and CrystalDiskmark results, with BIOS version highlighted in msinfo32.exe in the background.
ver 0046
Jean_Intel
Hello Jay_W,
Thanks for the screenshots.
I will continue to investigate the issue internally.
Jean O.
Jean_Intel
Hello Jay_W,
Thanks for waiting for a response.
We have ended our investigation, and we were able to replicate the issue. However, you should know that the fix will take a couple of months.
Jean O.
Busdriver
Similar results here:
BIOS
Version
0052
Date
4/25/2022
MOTHERBOARD
Manufacturer
Intel Corporation
Model
NUC12EDBi9
Version
M27907-302
OPERATING SYSTEM
Edition Microsoft Windows 11 Pro (64-bit)
Version (Build) 21H2 (10.0.22000)
It appears only M.2 slot 0 (closest to CPU) providing full speed.
FireCuda 530 slot 0
FireCuda 530 slot 0FireCuda 530 slot 0
FireCuda 530 slot 1
Similar results with Samsung EVO 960
Jean_Intel
Hello @Busdriver.
Please submit a new question on the Nuc community forums, and provide a detailed explanation of the situation to have a more personalized troubleshooting step for your issue. If you'd like, you can try my suggestions from this thread.
Jean O.
Jean_Intel
Hello @Jay_W,
Jean O.
Jay_W
That does seem to bring SSD perf back to the expected level. Thanks!
M56
I have the exact same situation as described above. Full speed using the slot nearest the CPU, one third speed using the other two slots. Is there a solution other than waiting 2 months for a new bios?
Tested using Windows 11, Samsung 980 Pro 512, Sabrent Rocket Plus 512
Jean_Intel
Hello @M56.
Jean O.
Jean_Intel
Hello @Jay_W,
I am glad to hear that the issue is now solved and everything is working fine.
Kind Regards,
Jean O.
crhendo
"I am glad to hear that the issue is now solved and everything is working fine.
If you need any additional information, please submit a new question as this thread will no longer be monitored."
I can also report that only the slot next to the CPU provides the correct performance.  In your quote you say that the issue is solved. What has changed?
Jay_W
Intel sent me a debug version BIOS probably with a fix in it. Unfortunately, the instructions say I cannot share it.
But anyways, before flashing the debug BIOS, I can get the expected perf by reverting to BIOS v0046.
crhendo
Thanks for letting me know. Let's hope that a major bug like this one will be fixed in faster than 2 months!!!!!
