Intel® NUCs
Support for Intel® NUC products
12755 Discussions
NUC12DCMi9 with Nvidia 4070Ti?
crhendo
I notice that the newly announced Nvidia 12GB 4070Ti card has been advertised as a "2 slot" card and the power draw is less than the 3080. Any thoughts on whether or not this ridiculously priced card will be compatible with the NUC12DCMi9 would be most welcome.
crhendo
I am pleased to advise that the INNO3D GEFORCE RTX 4070 Ti X3 OC is now running on my NUC12DCMi9. I had to make a minor (ie not too technical) modification to the supplied PCIE 5 to dual type 4 power cable to enable it to fit under the top exhaust fans. The 4070 Ti is 10mm longer and approximately 3mm skinnier than the 3080. The 4070 Ti is quieter than the 12GB EVGA 3080 and uses 10% to 20% less wattage (measured at the wall) to perform similar tasks. While I am not a gamer, I thought I would run a few easily obtainable tests before and after the install of the 4070 Ti.  In all cases, the larger number is the winner.
        12GB EVGA 3080                      12GB INNO3D 4070 Ti
  1. Geekbench 5.4.5 OpenCL score                               207673                                            216922
  2. Geekbench 5.4.5 CUDA score                                   230434                                            225038
  3. Geekbench 5.4.5 Vulkan score                                 102190                                               94261
  4. 3DMark Speed Way                                                          4883                                                 5409
  5. 3DMark Time Spy                                                           16778                                               19739
  6. 3DMark Time Spy Extreme                                             8457                                                 9688
  7. 3DMark DirectX Raytracing                                            49.25                                                67.59
  8. 3dMark DLSS (without DLSS)                                        55.31                                                63.43
  9. 3dMark DLSS (with DLSS)*                                          121.86                                              159.63
* for each DLSS test I used an output size of 2560x1440. Also, I could only use DLSS 2 on the 3080 and DLSS 3 on the 4070 Ti
Hoson
I also asking the wide for "triple-slot" from another post.
I checked two smaller 4070Ti cards at this moment are: (around 12", if you can find another, pls let me know)
ZOTAC GAMING GeForce RTX 4070 Ti Trinity OC
MSI GeForce RTX™ 4070 Ti VENTUS 3X 12G OC
Maybe u need check the wide is suitable for your NUC 12?
Alberto_R_Intel
crhendo, Thank you for posting in the Intel® Communities Support.
In reference to your question, it is important to mention that Intel® has not tested or validated the Nvidia 4070Ti card as compatible with your Intel® NUC 12 Extreme Kit - NUC12DCMi9, as you can confirm when using our compatibility tool:
https://compatibleproducts.intel.com/ProductDetails?activeModule=Intel%C2%AE%20NUC&prdName=NUC12DCMi9%C2%A0
Based on that, we cannot guarantee that the card will work with your Intel® NUC.
Still, in the link below you will find the TPS (Technical Product Specifications) of your device, where you can verify the dimensions of it, page 36:
https://www.intel.com/content/dam/support/us/en/documents/intel-nuc/NUC12DCM_NUC12EDB_TechProdSpec.pdf
Additionally, the graphics cards might have a high power consumption that the Intel® NUC might not be able to provide. For that reason, we recomned to get in contact directly with Nivida Support to confirm with them all the specifications about their product:
https://www.nvidia.com/en-us/support/
Albert R.
crhendo
The specifications of the INNO3d 4070ti size wise are a perfect fit with a power draw less than the 3080. What else do I need to know? When will Intel test this board?
Alberto_R_Intel
crhendo, Thank you very much for your response.
In reference to your question, from our side, those are all the details we have available for this scenario.
There is no official information on when Intel® will test this board or if it will be tested since it is almost impossible for Intel® to test all the products available in the market.
Albert R.
crhendo
Alberto_R_Intel
crhendo, Thank you very much for letting us know those updates.
Perfect, excellent, it is great to know that you were able to install the graphics card on the Intel® NUC and that it is working properly.
Thank you also for sharing the results in the thread, we are sure they will be very helpful and useful to all the peers looking at this conversation.
Any other inquiries, do not hesitate to contact us again.
Albert R.
