Hello
With my NUC12WSHi5 (Win11, latest drivers installed). I only get a FullHD resolution via the certified TB > HDMI (cable matters) cable.
What could be the problem?
DerFennek, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance on this matter, we just wanted to confirm a few details about your system:
Is this a new Intel® NUC?
When did you purchase it?
What is the model of your monitor?
Were you able to use a higher resolution on this specific device before?
If yes, when did the issue start?
Did you make any recent hardware/software changes that might cause this issue?
Albert R.
You probably need a Firmware Update to fix Compatibility and Performance Issues on the Cable Matters product. Converter Cables contain chips that can be flashed when the product is plugged.
Which product are you using?
