Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13500 Discussions
NUC12WSHi7 wired network speed stuck at 100mbit
stjohn
I bought an INTEL NUC12WSHi7 but only get 100mbit throughput of the wired ethernet in linux.
I have tried Ubuntu 20.04, Ubuntu 22.04, Debian 11 with several different kernels. Same result.
The nic is the 225-v rev 3.
There seems to be lot's of people having similar issues.
What should I do?
Steven_Intel
Hello stjohn,
I am sorry you are having issues with your Intel® NUC 12 Pro Kit NUC12WSHi7, I will be glad to help you.
Please provide the following information:
Steven G.
stjohn
Hey!
  • Have you installed the latest Ethernet driver 1.1.3.34 (https://www.intel.com/content/www/us/en/download/739770/intel-ethernet-lan-network-connection-driver...)? - Yes
  • Have you tried with different Ethernet cables? - Yes, 4 different (all of them gives me 1gbit with other computers)
  • Does it get stuck at 100 Mbps even when connected to a different network? - Yes, tried 2 different switches and 1 router.
  • How are you measuring the speed? - Both by checking the link status on the switches/router and within the nuc itself as well as with different "speed"-services.
  • I have also tried to force it to use 1gbit from both nuc side and switch/router side - making it lose link completely.
I have been in contact with Intel technical support via my reseller, he said it's probably a faulty card.
I'm now in contact with my reseller to get a new one - or if that fails, I'll contact Intel again.
Steven_Intel
Many thanks for your response.
Please let us know the outcome of trying the replacement card.
Steven G.
Steven_Intel
We would like to know if you were you able to check the previous post.
Steven G.
stjohn
Hi!
A new nuc from my reseller solved it. Moved disk and ram over and it worked immediately after booting.
1gbit stable connection.
Steven_Intel
Thank you for letting us know you were able to solve the issue.
Since the thread is now solved, we will proceed to close it. Please keep in mind that this thread will no longer be monitored by Intel.
Steven G.
