Intel® NUCs
Assistance in Intel® NUC products
13301 Discussions
NUC12WSKI5000 with2x HDMI and 2x DP/USB-C cannot drive 2x HDMI
Knulli
I cannot get it work to connect 2x HDMI Monitors on my NUC.
Using 1st HDMI Port with first Monitor, it works.
Using 2nd HDMI Port with other Monitor, works too.
But using both HDMI ports with two Monitors at same time will not work.
Windows11 will not detect a second Monitor.
Any ideas?
I found a scheme, where some setups are described:
https://www.intel.com/content/www/us/en/support/articles/000091798/intel-nuc.html
Do they forgot to paint a 2x HDMI setup or is it really not possible?
But I can't believe that my simple setup should not supported.
Do i have to buy a new Monitor?????
Knulli
DeividA_Intel
Hello Knulli,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® NUC 12 Pro Mini PC NUC12WSKi5.
Both monitors should work with HDMI, in order to better assist you, please provide the following:
1. What is the resolution that you want to use with both monitors?
2. What is the graphics driver version installed?
3. What is the BIOS version installed?
4. What is the Windows version and build installed?
5. To confirm, when both monitors are connected, is only one monitor working, or does none of them give a display?
Deivid A.
DeividA_Intel
Hello Knulli,
After checking your thread, I would like to know if you need further assistance.
If so, please let me know.
Deivid A.
DeividA_Intel
Hello Knulli,
I was checking your thread and see that we have not heard back from you.
I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
