Community
cancel
Showing results for
Search instead for
Did you mean:
KReis2
NUC513MYBE power switch bypass
Jump to solution
I have the same problem as described in https://intel-openport-v8.hosted.jivesoftware.com/thread/121840 NUC5i5MYBE Power Switch Bypass |Intel Communities
In my case, I have a NUC5i3MYBE board, updated to BIOS Version MYBDW130.86A.0044, embedded inside an appliance that contains its own internal power supply. I'd like to disable the board's power switch pushbutton to allow complete boot-up upon powering the appliance as a whole. It's currently necessary to tap the NUC's on-board power switch after supplying power but that switch won't be accessible on a finished appliance.
I followed the suggested solution in the other question and checked the BIOS Power Sense and selected "Power On" from the After Power Failure menu in the tab's Secondary Power Settings pane. The only other option checked in that pane is PCIe ASPM Support. With those settings, the NUC still doesn't attempt to boot when powered until the button is pressed.
A wrinkle is that the NUC has FreeBSD 10.4 installed.
n_scott_pearson
Super User Retired Employee
This feature is working just fine for me. If powered off, the reapplication of power will cause the MY NUC to wake and boot into the O/S (whether it is Windows or Linux doesn't matter; we are talking about a pre-boot feature here).
I have the following settings enabled (checked/set) in the Secondary Power Settings window:
Power Sense Checked
After Power Failure Power On
PCIe ASPM Support Checked
Native ACPI OS PCIe Support Checked
Hope this helps,
n_scott_pearson
Power Sense Checked
Hope this helps,
KReis2
Thank you! That was it - I was missing the "Native ACPI OS PCIe Support" setting.
