Community
cancel
Showing results for
Search instead for
Did you mean:
CFaur
NUC5CAYS no boot possible
Hi
i'have a new recent problem with my NUC.
Windows 10 is not bootable since update of Windows... don't understand what happened. i only restart my nuc then he refused to start with this 2 messages:
"checking media presence" then "A bootable device has not been detected"
i have not do anything (only restart the NUC)
i try recovery: impossible
i've no save backup image
i can access with prompt command with the F8 menu recovery mode (X:\windows\system32) and can do command but not admin in mode.
Chkdsk no error
sfc /scannow no result cause admin problem.
what can i do to restore the bootable device windows 10??? hardware issue on memory flash? software error cause windows update??? i search on th net but no solutions find...
help please
Thx
CFaur
sorry it's a NUC6CAYS !
mistake in the title
LeonWaksman
1. If you know how to access Command Prompt, write there the following command:
bcdedit /set {default} safeboot minimal
Press enter
after executing this command write:
exit
Press enter
and close the Command Prompt
2. Reboot your NUC. It should boot to Windows in Safe Mode.
3. While in Windows, press Windows key + r. Run msconfig
4. Chose Boot tab and uncheck Safe boot. Reboot your system.
Note:
You can enter Command Prompt when booting form Windows 10 installation USB into Advanced Menu: https://www.tenforums.com/tutorials/2294-boot-advanced-startup-options-windows-10-a.html Windows 10 Help Forums
Hope this will help
Leon
CFaur
Thanks for advises and help
clear cmos no effects but i finally find an old backup of Dec-2017 on my SSD (i'm lucky having do that)
i restore this backup and win10 now boot correctly (lost some data but no care) ==> the problem was the bootable part of windows that was probably damaging after the win update... doesn't understand why.
i upgrade all bios and drivers of my NUC and it's ok.
then i install new update of win10 and i notice that the package "1803" april 2018 seems not to work well on NUC6CAYS. i get some new troubles with it but finally it's. Maybe UEFI troubles with this package because my bios was not the last ?
my NUC is now working well again. i make a new recent backup !
thanks for help i keep your commands! (but finally not try them... sorry)
bye
