Community
cancel
Showing results for
Search instead for
Did you mean:
ECola
NUC5CPYB : drivers windows 7
Hi
I try to install W7 on my NUC5CPYB. I can't install W7 actually because my keyboard is not recognize due to USB 3.0.
I follow the steps to add drivers but it does not work...
During the mounting, the systm block "cleaning up and mounting" during hours..
How can I install W7 on my computer ?
BOnjour
je cherche à installer W7 sur mon NUC5CPYB. Dans l'install je suis bloquée du fait de la non prise en charge de l'USB 3.0.
J'ai donc suivi la procédure décrite pour ajouter les drivers nécessaires, mais cela ne fonctionne pas.
Au moment du montage, cela s'arrête sur "Cleaning up and mounting..." et cela ne s'arrête jamais.
Comment puis je faire pour installer W7 ?
MErci
Tags (1)
n_scott_pearson
Super User Retired Employee
What kind of PC (i.e. what version of Windows) are you using to update the installation image? I have had better success doing it on a system running Windows 8.1 or Windows 10.
ECola
I update the installation image on a system running Windows 10 ...
I can try on a system running W7 ...
I try this :
- creating iso image with Rufus on a computer running on windows 7
- i try to run Windows 7* USB 3.0 Creator Utility but an error message "can't open this application"...
- so I try to run Windows 7* USB 3.0 Creator Utility on my system runing on windows 10 but here :
Windows 7 HOMEBASIC
Mounting image... Error: 0xC1420127
Image already mounted"
What can I do ???
n_scott_pearson
If you reach this point, your only alternative is to run the DISM commands manually. Here is a script that I put together that shows the commands that you need to do:
@echo off
rem rem rem rem rem rem rem rem rem rem rem rem rem rem rem rem rem rem rem rem
rem
rem File: USB3WIMUpdate.bat
rem
rem Purpose: Updates WIM files BOOT.WIM and INSTALL.WIM (if present)
rem with the USB 3.0 driver files.
rem
rem Notes: 1. Presumes USB 3.0 driver files are present within subfolder USB3.
rem
rem 2. Presumes correct version of DISM is present in the current folder (bring
rem it from the ISO image along with the BOOT.WIM and INSTALL.WIM files).
rem
rem 3. If the mount subfolder does not exist, it will be created. If the mount
rem subfolder already exists, it will be cleared out before proceeding.
rem
rem 4. Ping commands implement a 120 second sleep. This is to allow the
rem DISM background processes time to complete.
rem
rem Clear out the mount subfolder
if exist mount rmdir /s /q mount
mkdir mount
rem Update the drivers in the boot.wim file
dism /mount-wim /wimfile:boot.wim /index:2 /mountdir:mount
dism /image:mount /add-driver:"usb3" /recurse
ping 1.1.1.1 -n 1 -w 120000 >NUL
dism /unmount-wim /mountdir:mount /commit
rem Update the drivers in the install.wim file for Windows 7 Home Basic
dism /mount-wim /wimfile:install.wim /index:1 /mountdir:mount
rem Update the drivers in the install.wim file for Windows 7 Premium
dism /mount-wim /wimfile:install.wim /index:2 /mountdir:mount
rem Update the drivers in the install.wim file for Windows 7 Professional
dism /mount-wim /wimfile:install.wim /index:3 /mountdir:mount
rem Update the drivers in the install.wim file for Windows 7 Ultimate
dism /mount-wim /wimfile:install.wim /index:4 /mountdir:mount
Do not try to use this script! Even with the delay operations (I use ping command to implement the d...
Community Manager
Hello zazou35,
This is to do a follow up on your case and find out if you were able to get this working as desired or if you had further questions.
Esteban C
ECola
Yes I try to find a solution to my problem. I contact the assitance of intel and now it works.
I mount the image iso with commands line in W10.
Community Manager
I am glad to hear you were able to get this working as desired. zazou35
Feel free to contact us back if required.
Esteban C
