Intel® NUCs
12748 Discussions
NUC5I3RYH graphic driver HD 5500 issue with HDMI output
RYane1
I have mini PC NUC5I3RYH with windows 7, mini HDMI to HDMI port connection to monitor.
Recently, the monitor has turned black after OS started. I can hear sounds of OS, I can restart the computer by using keybord buttons, but the monitor is black.
1. I started a computer in safe mode and disabled the graphic driver Intel HD 5500. The monitor shows correct picture.
2. I tried to install previous version of the driver - monitor is black.
3. Currently computers works with standard video controller.
4. I have re-installed OS (windows 7), same issue - after installing of graphic driver (monitor is black)
5. Intel Driver and Support assistant could not help either.
RYane1
Hi Amy.
The seller refused to test the computer.
I was told that it was purchased on 18.08.2015, the warranty was ended on 17.08.2018.
Thank you very much for assistance.
Thank you for the update RonnyY.
Please, check you inbox for more details.
Amy C.
