We have +/- 300 NUC5i3MYBE devices with amplifier and speakers.
At boot we hear a very loud beep when we press the powerbutton longer than 1 sec.
So a quick press gives no issues..
Does anyone knows how to disable this beep ? I cannot find any option in the Visual Bios....
any help appreciated
Johan
Hi belgium123: We will do our best to provide the information you are looking for.
In regard to your question, there is no need to press and hold the power key for more that 1 second, you can always do that to access the power button menu as you can see on the following link on page 82:
https://www.intel.com/content/dam/support/us/en/documents/boardsandkits/NUC5i3MYBE_TechProdSpec.pdf https://www.intel.com/content/dam/support/us/en/documents/boardsandkits/NUC5i3MYBE_TechProdSpec.pdf
Did you test at least one unit without the Amplifier and Speakers to rule out a possible compatibility issues?
If the problem remains after that, please provide the SSU report from one of the NUCs while the speakers and amplifiers are connected:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Alberto R.
Under Contract to Intel Corporation
"there is no need to press and hold the power key for more that 1 second"
Yes but users do it quite often...
Now I have board with uncoupled from amplifier;
hereby the ssu report:
# SSU Scan Information
Scan Info:
Version:"1.0.0.0"
Scan Date:"2018/09/27"
Scan Time:"10:00:18"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"Intel Corporation"
Bios Mode:"Legacy"
Bios Version/Date:"MYBDWi5v.86A.0031.2016.0913.1113,09/13/2016"
CD or DVD:"Not Available"
Platform Role:"Linux id-0003163 4.4.0-112-generic # 135-Ubuntu SMP Fri Jan 19 11:48:36 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux"
Processor:"Intel(R) Core(TM) i5-5300U CPU @ 2.30GHz"
Serial Number:" "
SMBIOS Version:"2.8"
Sound Cards:"HDA-Intel - HDA Intel HDMI"
Sound Cards:"HDA Intel HDMI at 0xaa134000 irq 48"
Sound Cards:"HDA-Intel - HDA Intel PCH"
Sound Cards:"HDA Intel PCH at 0xaa130000 irq 47"
System Manufacturer:" "
System Model:" "
System Type:"x64-based PC"
- Display
- "Intel Corporation Broadwell-U Integrated Graphics (rev 09) (prog-if 00 [VGA controller])"
Adapter RAM:"size=256M"
Capabilities:"[90] MSI: Enable+ Count=1/1 Maskable- 64bit-"
Capabilities:"[d0] Power Management version 2"
Capabilities:"[a4] PCI Advanced Features"
Caption:"Intel Corporation Broadwell-U Integrated Graphics (rev 09) (prog-if 00 [VGA controller])"
Device ID:"8086:2058"
Driver:"i915"
Driver Path:"/lib/modules/4.4.0-112-generic/kernel/drivers/gpu/drm/i915/i915.ko"
Driver Provider:"Intel Corporation"
Driver Provider:"Tungsten Graphics, Inc."
Driver Version:""
Flags:"bus master, fast devsel, latency 0, IRQ 45"
I/O Ports:"I/O ports at 3000 [size=64]"
Manufacturer:"Intel Corporation [8086]"
Power Management Capabilities:"Power Management version 2"
Refresh Rate - Current:"Not Available"
Resolution:"Not Available"
- Memory
Physical Memory (Available):"2635 MB"
Physical Memory (Installed):"3820 MB"
Physical Memory (Total):"7783 MB"
- "SODIMM0"
Capacity:"4096 MB"
Configured Clock Speed:"1600 MHz"
Configured Voltage:"Unknown"
Data Width:"64 bits"
Form Factor:"SODIMM"
Interleave Position:"First Position"
Locator:"SODIMM0"
Manufacturer:"Kingston"
Maximum Voltage:"Unknown"
Minimum Voltage:"Unknown"
Part Number:"9U5469-045.A00LF"
Serial Number:"5F2E7923"
Speed:"Not Available"
Type:"Synchronous"
- Motherboard
Product:"NUC5i5MYBE"
Serial Number:"GEMY71000JVK"
Version:"H47797-207"
- Networking
- "Intel Corporation Ethernet Connection (3) I218-LM (rev 03)"
Supports auto-negotiation:"Yes"
Advertised auto-negotiation:"Yes"
Auto-negotiation:"on"
Availability:"UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1"
Capabilities:"[c8] Power Management version 2"
Capabilities:"[d0] MSI: Enable+ Count=1/1 Maskable- 64bit+"
Capabilities:"[e0] PCI Advanced Features"
Caption:"Not Available"
Default IP Gateway:"10.30.200.2"
DHCP Enabled:"Yes"
DHCP Lease Expires:"07:44:36"
DHCP Lease Obtained:"sep 27 09:44"
DHCP Server:"10.30.200.4"
Driver:"e1000e"
Driver Path:"/lib/modules/4.4.0-112-generic/kernel/drivers/net/ethernet/intel/e1000e/e1000e.ko"
Driver Provider:"Intel Corporation, <</span>mailto:linux.nics@intel.com linux.nics@intel.com>"
Driver Version:""
Duplex:"Full"
Firmware Version:"0.2-4"
Interface:"enp0s25"
I/O Ports:"Not Available"
IP Address:"10.30.207.220"
IP Subnet:"255.255.248.0"
MAC Address:"f4:4d:30:6b:c9:1f"
Net Connection ID:"Ethernet"
Port:"Twisted Pair"
Power Management:"Supports Wake-on: pumbg"
Power Management:"Wake-on: g"
Speed:"1000Mb/s"
Supported link modes:"10baseT/Half 10baseT/Full, 100baseT/Half 100baseT/Full, 1000baseT/Full"...
belgium123: Thank you very much for providing that information.
We recommend to educate the users to try not to press and hold the power key for more than 1 second since this will bring up the Power Button Menu.
This is expected behavior.
If the customer is using headphones they should hear three beeps when accessing the Power Button Menu.
With speakers, that may be why they are hearing one.
On a side note, I was checking the memory RAM listed in the SSU report provided and I can only find links to Toshiba laptops for the memory.
The proper memory RAM for the Intel® NUC should be:
DDR3L-1333/1600 1.35V SO-DIMM
https://ark.intel.com/products/84863/Intel-NUC-Board-NUC5i3MYBE
Please verify that the customers are using the correct memory RAM quantity and the proper speed and voltage to avoid any possible issues.
Alberto R.
Dear,
Thanks for the answer.
Plz note that we do not see "Power Button Menu" on the screen.
We tested with headphones an hear only one beep...
Can the beeps or audible notifications be turned of by a bios update/patch ?
We have around 400 units in the field and a firste case where a person has hearing damage caused by the beep...
So any help appreciated
Johan
Hi: belgium123
I sent you a private message, please check your inbox.
Alberto R.
