Community
cancel
Showing results for
Search instead for
Did you mean:
弘鵜沢
NUC5i3RYK Win10 Ver1803 Bluetooth To lose functionality
Bluetooth adapter is no longer recognized by Win10 Ver1803
Although the Bluetooth adapter is recognized during the clean installation of Ver1803
The Bluetooth adapter will not function if you reboot several times
Universal serial bus controller
An unknown USB device device descriptor request failure code 43 appears
Bios version: 0369
Bluetooth version 20.40.0.3
Check with
Community Manager
Hello Uz,
I understand that you are facing functionality issues with the Bluetooth of your NUC5i3RYK.
In order to assist you, please go ahead and try a BIOS recovery by following these steps:
https://www.intel.com/content/www/us/en/support/articles/000005532/mini-pcs.html https://www.intel.com/content/www/us/en/support/articles/000005532/mini-pcs.html
Here you will find the attest version of the BIOS, which is already on your system:
https://downloadcenter.intel.com/download/27631/BIOS-Update-RYBDWi35-86A-?product=83256 https://downloadcenter.intel.com/download/27631/BIOS-Update-RYBDWi35-86A-?product=83256
Once that you recover the BIOS please go ahead and try to install the latest Intel® Bluetooth Technology-Based Driver for Windows® 10 found here:
https://downloadcenter.intel.com/download/27602/Intel-Bluetooth-Technology-Based-Driver-for-Windows-... https://downloadcenter.intel.com/download/27602/Intel-Bluetooth-Technology-Based-Driver-for-Windows-...
Please let us know the outcome; I hope to hear from you soon.
Diego S.
弘鵜沢
Win10 Ver1803 Automatically installed by WindowsUpdate
BluetoothDriver ver 20.40.0.3 seems to have caused the error.
When I changed to BluetoothDriver ver 20.30.0.3 the error no longer exists
Unknown usb device Device descriptor request failure code 43 Error The problem has been resolved.
Thank you
n_scott_pearson
Super User Retired Employee
Back when the Fall Creator's Update came out, we had all sorts of issues with BT. This was a MS issue. I am presuming the same goes for the Spring Creator's Update. Do the following:
1. Download latest WiFi and BT drivers fron Intel Download Center and copy onto NUC.
2. Disable internet access.
3. Totally uninstall the WiFi and BT drivers.
4. Reboot.
5. Install BT and then WiFi drivers.
6. Reboot and test.
Hope this helps,
