Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
NUC5i5MY - In Ubuntu 16.04, using tpm2.0-tools from Intel's 01org, how do we use the TPM to sign a file?
Jump to solution
Need help with TPM 2.0 key configuration for a NUC5i5MY running Ubuntu 16.04, using tpm2.0-tools from Intel's 01org.
I was able to make a primary key, but I haven't had luck with a signing key yet...
Instructions:
sudo apt-get install tpm2-tools
then
sudo resourcemgr
Intel's software is the one that comes in Ubuntu by default: tpm2-tools in the package manager or online at https://github.com/01org/tpm2.0-tools https://github.com/01org/tpm2.0-tools
I need to check the spec again, but from what I remember, the first thing you need to do
is take ownership, then create a primary key, then a signing key.
OR can anyone recommend an alternative to Intel's tpm2.0-tools - know of an implementation of the tools for 2.0?
HELP!
Tags (1)
Community Manager
Hello, ziggydoran:
Thank you for contacting the Intel Communities.
In this case, I would like to recommend you to contact the communities support from 01.org, this communities support is specialized in Linux and would be the place to go in order to get support on this inquiry.
Peers overthere will help you for sure.
This is the link for the communities support for Linux: https://01.org/community https://01.org/community
Hope you can get in touch with them in order to get this fixed/answered.
If any additional inquiries are present related to Intel products, feel free to contact us back.
Esteban C
Community Manager
Hello, ziggydoran:
Esteban C
Community Manager
Thank you Esteban your feedback - will post our question at 01.org forums as suggested
Community Manager
Not a problem ziggydoran, and thank you for understanding this, hope you get the inquiry answered soon.
Esteban C
ZSmit3
ziggydoran,
I am having a problem almost exactly similar to yours. Did you ever get answers from 01.org?
Community Manager
Hi, mikzaq:
I was trying to look for the possible inquiry posted by ziggydoran but didn't find it.
I would like to recommend you to post your inquiry directly in this specialized forum support for Ubuntu.
Esteban C
