Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
NUC5i5MYBE Power Switch Bypass
Jump to solution
I am using NUC5i5MYBE board. The board is going to be mounted in a closed cabinet. I am using internal power supply to power on the board.
After giving power supply, I have to use the power switch. How can I bypass the power switch to power on the board just by using internal power supply?
Mayank
Accepted Solutions
Highlighted
Community Manager
Hello, Maysri.
Thank you very much for taking the time to reach the Intel® Communities Team.
I understand you would like to know how to turn on your NUC by using the internal power supply you have.
In this case, for you to achieve so, please follow these steps:
  1. While your NUC is Posting, press F2 to enter the BIOS Graphic Interface.
  2. Go to Advanced settings and click on Power tab.
  3. Make sure the Power Sense option is checked if not, please mark it.
  4. Then, click on the After Power Failure dropdown.
  5. In the drop-down click on Turn On.
  6. Press F10 to save the changes.
Antony S.
Highlighted
Community Manager
Hello, Maysri.
Antony S.
Highlighted
Thanks for the support Antony.
Mayank
Highlighted
Community Manager
Hello, Maysri.
You are more than welcome, it was my pleasure to assist you regarding your inquiry.
Antony S.
