Community
cancel
Showing results for
Search instead for
Did you mean:
JRayn
NUC5i5RYH Power Off
Quick question.
Does removing the power cable, leaving the box overnight and then re-powering up the next day have any effect either adverse or advantageous?
n_scott_pearson
Super User Retired Employee
No advantage at all - and lots of disadvantages. Use power management to have it sleep and do maintenance during the unused periods.
JRayn
Thank you for your response. I am intrigued now. What would be the lots of disadvantages?
AlHill
Yep, lots of things occur when the lights are out. And, it does not hurt to restart now and then, especially if you are not paying attention to any reboot warnings.
Doc
n_scott_pearson
Regularly disconnecting and connecting power is not good for any electronic device and could cause issues long-term. Spinning HDDs especially don't like it. Having to fully reboot every day is a time penalty. It also means that all maintenance (and Windows 10 does a lot of it!) is done while you are present. Need I go on?
JRayn
Right, I've got it now. Thanks for your input.
