Community
cancel
Showing results for
Search instead for
Did you mean:
BMøll
NUC5i7RHI First time boot from USB 3.0 with Windows 10 key.
Boot agent GE v1.5.
"Insert Boot Media in selectet Boot device"
USB key Wnndows 10 inserted i port USB3.0
Returning "No boot filename recieved".
Please Help
EBM Denmark
IUman
Hello EBM_Denmark,
Thank you for joining the Intel communities.
This error can occur if the boot device is not found in network boot, where the system tries to boot from Network. Let's try to solve this problem. Restart your system and press F2 when you get the prompts, that will make you enter the BIOS and once you're there press F9 on your keyboard to set the BIOS to the default settings. Select advance, in the Boot tab select boot priority, Check UEFI boot and legacy boot, press F10 to save the changes, your system will restart and when that's happening press F10 on your keyboard to access the F10 BIOS and when you're there select the USB device where you have the operating system to install it.
I hope this can help you!
Best regards!
Ivan
BMøll
Hello Ivan
Thank you for the answer, very helpfull.
Best regard
Bo Møller
IUman
I'm glad to hear that this information was very helpful for you.
Don't hesitate to contact us again if need anything else.
Best wishes
Ivan
