Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
NUC5i7RYH crashing in ubuntu 14.04
Jump to solution
My boss asked me to set him up with an NUC (current computer locks up with two screens).
I have gone for
NUC5I7RYH
Kingston HyperX Predator—240 GB SHPM2280P2/240G
Kingston KVR16LS11/4 4 GB 1600 MHz x 2 ie 8GB memory
I have installed Ubuntu 14.04.3 LTS and fully upgraded it. The NUC Bios appears to be the very latest.
System is mainly working well, but I have encountered a repeatable crash running Virtualbox 5.03 when trying to import a
Microsoft Windows 10 + MSEdge test appliance(.ova). The crash seems to cause complete loss of access to the file
system (the underlying drive appears OK, but the system seems to be running in memory only).
I have looked in the logs, but cannot see anything related to the crash which I suppose is reasonable given that we lose
access to the disk.
I have exploded a different MS .ova (for IE9+ Windows 7) on the NUC and I have exploded the offending .ova on another
linux box with the same software.
Any ideas where I should start trying to figure this out?
Tags (1)
Accepted Solutions
Highlighted
1 View
Re: NUC5i7RYH crashing in ubuntu 14.04
Jump to solution
Hi replab_robin,
Intel tested the NUCs with the basic configuration of Linux distributions; I suggest you to search or post your question at http://ubuntuforums.org/ Ubuntu Forums
From our side, the latest BIOS version is 0350. It is available at https://downloadcenter.intel.com/product/87570/Intel-NUC-Kit-NUC5i7RYH Downloads for Intel® NUC Kit NUC5i7RYH
Mike C
Highlighted
Jump to solution
Hi replab_robin,
Mike C
