hello
I have NUC above and my wifi adapter should be able to connect to AC router 5G which it does but only at 802.11n speed which is 300mbps
and the device properties in windows only shows 802.11n channel bandwidth
my router is asus RT-ACRH13
my adapter driver is the latest already 19.60
thanks
Hello Magrody
Thank you for joining the Intel® NUC community. My apologizes for the inconvenience.
Please let me review this matter, I will update the thread as soon as possible.
Amy C.
/thread/117820 Magrody,
To enable 802.11n/ac, keep the default setting for Wireless mode. Select HT mode for 802.11n, or VHT mode for 802.11ac under HT mode.
Remember AC only works at 5Ghz and the router should support AC mode.
Amy C.
Amy,
I'm using all recommended settings including "MHT" as shown in attached snap
also if you check the attachment in the first message you will find that the first line in advanced options says
"802.11n channel width"
it doesn't identify itself as 802.11ac capable adapter regardless of router setup or anything else
however my router is Asus ACRH-RT13 and i am connected to 5.2 GHZ chanel
Thanks /thread/117820 Magrody.
Let double check this.
Amy C.
/thread/117820 Magrody, thank you for patience.
Please try to set a fixed channel at router level. Like for example 136 for 5 GHz, for this you will need to check with ASUS how to achieve this. All settings are correct and it should get up to 867 Mbps with that configuration. We believe that there are environmental details that are no allowing to get up to that speed and probably more networks sharing the same channel.
Amy C.
amy, no problem
but if this is the case it doesn't explain why the wifi adapter driver reads "802.11n"
if it was environment it would connect at a low speed but states "802.11ac"
don't you think?
ok you win
the old router was still running and turning it off solved the problem
it was on 2.4 GHZ so i assumed it can never interfer
now i am getting varied performance ranging from 300 and up to 700 Mbps
is there any recommendation for settings in adapter or router other than this page:
https://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000024678.html Recommended Settings for 802.11ac Connectivity
also it changes alot through the range between 300 and 700 without changing anything
why do you think that happens?
thanks for your help
/thread/117820 Magrody, I am glad to hear that!
Let me check if there is more information regarding this.
Thank you.
Amy C.
/thread/117820 Magrody, as it is connecting to 5 GHz it changes very easy depending of the environmental details .. walls, light, noise, other networks. Also if you have other devices connected that are older ones ( Like N versions) that will drop down performance to the slower ones connected to the same network. You could be sharing channel frequency with other networks around ( even those wireless land phones). As workaround you can try a different channel at access point level and not use auto. (change to lower channels). You will need to play with the configuration. Make sure that in the wireless setting the WMM is enabled.
Amy C.
I appreciate it
/thread/117820 Magrody sure, you're welcome.
If you have more questions, please let us know.
Amy C.
