One of our NUC failed recently, after investigation it seems that the SSD failed.
I changed the SSD and updated the NUC to latest Bios version (AY0064) using the recovery method (F7).
Usually, the bios update process show a success message after that but not for this NUC. It stop there and the Power button led turn off.
Is it normal or I may suspect a defect NUC ?
Also, there is nothing about EC Firmware while usually it also update the EC Firmware
Hello JPell1,
Thank you for posting on the Intel ® communities.
Are you experiencing issues when running the system after the update? If not, please let me know for more information.
If possible, go into the BIOS and check to see if the update was done successfully to the version you were trying.
Let me know please.
David V
A Contingent Worker at Intel
Hi, yes it seems to work properly and the bios update worked, it's a personalized bios built wit Intel toolkit.
I have hundreds of NUC6CAY systems, and those are the only 2 system I'm that do that, from what I know.
The same situation with my NUC7i5BNH. No 'success' message after BIOS 080 update - looks like the system is frozen.
After the manual reboot, it works properly.
Hello JPell1 and NS13,
Thank you for your replies.
For testing what I could recommend you to do is to perform a BIOS recovery, you can follow the steps in the link below:
https://www.intel.com/content/www/us/en/support/articles/000005532/mini-pcs.html
I would recommend following the "Power button" steps; nevertheless you can choose whichever option is better for you.
Let me know if the situation persists.
David V
Hello JPell1,
Were you able to check my previous post?
Let me know if you need more assistance.
David V
I tried the Recovery using Power Button but I can't get it work, never see the "Power Buttons Menu"
So I did it with "Security Jumper", which worked, but still don't see "EC Firmware" in the list.
Hello JPell1,
Thank you for your response.
Upon review of the information and the BIOS release notes, I can see that both the BIOS version 0063 and 0064 share the same version of EC firmware, this means that you will not see it on the list because there is no need to update it now.
David V
Hello JPell1,
Let me know if that clarifies why the EC firmware is not listed or if you need more assistance.
David V
Hi David,
Sorry for the delay, I was out of office last 2 weeks. I understand for the EC Firmware not listed but I expect to see a "completed successfully" message using the F7 method
Hello JPell1,
Please contact us if you have any additional questions.
David V
Hello JPell1
Thank you for this feedback I am going to send this through.
Leonardo C.
