We are experiencing issue with an Industrial Touch Screen Monitor, it seems that updating hdmi firmware to 1.72 resolve the issue.
It seems that brand new NUC6CAY still ship with the old 1.66 firmware so we must upgrade all systems manually here. We would like to automate the process as much as possible. Is it possible to upgrade the HDMI firmware using Intel Toolkit? Or launch the upgrade tool from command line?
Thanks!
- Tags:
- Intel® NUC 6th Gen
Hello JPell1,
Thank you for posting on the Intel ® communities.
You can either use the Intel ® Integrator Tool Kit or Intel ® VCUST tool to create images and attempt to automate the process; however, you will need to refer to the user guide for more information on how to do so, refer to the links below:
Intel ® Integrator Toolkit:
https://downloadcenter.intel.com/download/26307/Intel-Integrator-Toolkit
*NOTE: In the link you can also find a User guide*
Intel ® VCUST Tool:
https://downloadcenter.intel.com/download/28900/Intel-VCUST-Tool
Intel ® VCUST user guide:
https://www.intel.com/content/www/us/en/support/articles/000054982/mini-pcs.html
You can check the user guide and then you can set it up the way you would like.
David V
A Contingent Worker at Intel
Hi David,
From what I see, those tools doesn't allow an update of the HDMI Firmware? The only way I see seems to be using Windows 10
Hello JPell1,
Thank you for your response
Since that's the case, it can only be updated using the HDMI firmware update tool at:
https://downloadcenter.intel.com/download/26609/
David V
