Community
cancel
Showing results for
Search instead for
Did you mean:
AF_
NUC6CAYH LAN card disappered
I own a NUC6CAYH with last BIOS Version: 0048
Today I get aware that the Realtek LAN network card is disappered, only wifi works. I have Windows 10 with last updates.
I installed the last chipset driver and serial io too. I tried to installed the realtek driver but the wizard tells me Realtek car was not found.
I did shutdown, removed the power cable many times but the NIC does not appears. Replace also the network cable and plug it on another device that works.
On NUC6CAYH BIOS I get the MAC address is ff-ff-ff-ff-ff-ff.
How can I fix this problem?
Thank you
A.
Community Manager
Hello AFrntl,
Thank you for contacting us regarding the issue that you are experiencing in your LAN Card; I will do my best to help you.
Please go ahead and try a BIOS recovery through any of these methods:
https://www.intel.com/content/www/us/en/support/articles/000005532/mini-pcs.html https://www.intel.com/content/www/us/en/support/articles/000005532/mini-pcs.html
You will find the latest Bios for your machine here:
https://downloadcenter.intel.com/download/27753/BIOS-Update-AYAPLCEL-86A-?product=95062 https://downloadcenter.intel.com/download/27753/BIOS-Update-AYAPLCEL-86A-?product=95062
Please let us know the outcome, I hope to hear from you soon.
Diego S.
AF_
I did a recovery by the Power Button Menu steplist with last BIOS version. The procedure was successful.
However, I do not see any nic card on Windows: if I go to computer management and display the device list I did not see the realtek card or an unknown realtek device.
On BIOS the Onboard LAN MAC Address remains FF-FF-FF-FF-FF-FF
Community Manager
Hello AFrntl,
Thank you your response.
I have sent you a private message, please take a look at your inbox.
Diego S.
