Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
NUC6CAYH, Samsung UE28H4000AW, No Input Detected.
Hi there,
Unfortunately the combination of my NUC and tv doesn't work properly. HDMI 2.0 Firmware Update tool 1.66 installed.
Following are the details.
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
Turning on the tv, than the NUC, results in the tv not seeing any signal from the NUC connected to either ports HDMI 1 or HDMI 2 on the tv, mentioning "No input detected". The tv does flicker/switch once, noticing the NUC is starting. Neither the boot splash screen, nor the OS desktop is seen. The NUC boots successfully as i can connect to it over the network. Rebooting the NUC up to 10 times eventually results in showing the boot splash screen and the OS desktop. The VGA connection plugged into another display does not seem to have any problems. Re-plugging the HDMI cable has no effect, tv flickers/switches once but eventually will show "No Input detected". No connection/display issues at all with a satellite set top box connected to the same tv.
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
Always (100%): X
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):
Hardware (HW)
Brand and Model of the system.
Intel NUC6CAYH
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)
EFP. Samsung UE28H4000AW (UE28H4000AWXXN) television, firmware version 1042
How much memory [RAM] in the system (see note2 below).
8GB. 2 times Kingston KVR16LS11/4, 4GB PC3L.
Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etc<td style="border: 0px solid black; padding: 0 5.4pt 0 5.4pt; border-right: solid windowtext 1.0pt...
Highlighted
Seems i messed up the form, sorry for that. Will provide a new one if needed.
I'll repeat the problem description.
Samsung UE28H4000AW television rarely sees input from a NUC6CAYH. Needing up to 10 reboots of the NUC to see an input signal.
Tried with 3 different so called "high speed" HDMI cables, on both HDMI inputs on the tv. Selecting the correct input on the tv does not fix the issue.
Anything else i can try to solve this?
Jeroen
Highlighted
Community Manager
Hello Jeroen_,
Thank you for joining the Intel® NUC community. My apologies for the inconvenience.
Have you tested a different TV/monitor with the Intel® NUC?
I recommend testing the following driver version: https://downloadcenter.intel.com/download/26772/Graphics-Intel-Graphics-Driver-for-Windows-15-45- Download Intel® Graphics Driver for Windows* [15.45]
Amy C.
Highlighted
Hi Amy,
Thanks for the reply.
I've tried with the driver you linked. No difference at all unfortunately.
Also like you mentioned I've tried on another tv, a Samsung UE40EH5000wxxn. Unfortunately with the same result, "No Input Detected". Selecting the correct source input in the tv menu does not change the result.
Both tv's have no issues with satellite boxes or other computers connected to their HDMI inputs.
To me the issue seems to exist before the operating system loads. Most of the times not even the bios splash screen shows when starting the NUC. (bios splash screen: the text Intel® NUC in the middle of the screen, F2 to enter Setup and so on in the lower right.)
Jeroen.
Highlighted
Community Manager
Thanks Jeroen.
I would like to know if the cable you have tested are HDMI 2.0. Is there any chance to test a HDMI 2.0 cable version?
Amy C.
Highlighted
Hi Amy,
On both tv's i've tested with 3 cables.
1 generic/no brand "High speed HDMI cable"
1 generic/no brand "High speed HDMI cable with Ethernet"
1 Monster branded "Gold Advanced High Speed HDMI Cable with Ethernet", part number 140737-00.
With all 3 cables the same problem occurs.
Jeroen
Highlighted
Community Manager
Thanks Jeroen.
I was unable to confirm if these are 2.0 category. Can you confirm if any of those are HDMI 2.0 category?
Amy C.
Highlighted
Hi Amy,
I think all 3 cables are HDMI 2.0 compatible, based on this information from the HDMI Licensing Administrator.
https://www.hdmi.org/learningcenter/kb.aspx?c=17# 144 https://www.hdmi.org/learningcenter/kb.aspx?c=17# 144
https://www.hdmi.org/learningcenter/kb.aspx?c=17# 123 https://www.hdmi.org/learningcenter/kb.aspx?c=17# 123
The Monster branded cable mentions a guarantee of ">18.0 Gbps bandwidth".
https://www.monsterproducts.com/Monster-Gold-Advanced-High-Speed-HDMI-Cable-with-Ethernet https://www.monsterproducts.com/Monster-Gold-Advanced-High-Speed-HDMI-Cable-with-Ethernet
Apparently most of my friends and family have Samsung televisions of approximately the same age and series. Today i will try testing on another brand of television.
Jeroen.
Highlighted
Hi Ami,
The same issue, multiple reboots needed to get any display to show, occurs with the following tv models and 3 cables described in previous posts,
Samsung LE32R71B
Salora 22BL1700
Jeroen
Highlighted
Hi Ami,
After testing the last 2 tv's i went back to the shop where i bought the NUC, they've tested as well and agreed that the unit was faulty. They exchanged it for a new one which seems to work like it should. The issue is resolved.
Thank you very much for taking the time to help.
Jeroen
