Two DDR3L SO-DIMM sockets (up to 8 GB, 1866 MHz)
Look at section 1.4 on page 19:
https://www.intel.com/content/dam/support/us/en/documents/mini-pcs/nuc-kits/NUC6CAYS_NUC6CAYH_TechPr... https://www.intel.com/content/dam/support/us/en/documents/mini-pcs/nuc-kits/NUC6CAYS_NUC6CAYH_TechPr...
Note:DDR3L, not DDR3.
Doc
my mistake, ofc, now i have 2x Micron 4GB 1600MHz DDR3L Series (4GB 1Rx8 PC3L-12800S-11-11-B2)
Can you give the P/N of your RAM? This Micron 4GB 1600MHz DDR3L Series (4GB 1Rx8 PC3L-12800S-11-11-B2) is partial specification not P/N.
Leon
First of all, all memory is required to have x8 organization. Support is NOT provided for SODIMMs with x16 organization. Secondly, getting dual-ranked (2Rx8) memory instead of single-ranked (1Rx8) memory is not going to get you any better performance (no extra FPS). Third, only memory with 4Gb or 8Gb technology ICs can be used. Finally, since issues have been reported in the past with 2Rx8 memory (though not necessarily against the AY NUCs), I would avoid it if I were you.
Hope this helps,
There is a difference between dual ranked memory and dual channel memory mode. Actually single ranked memory is more expensive than dual ranked memory and theoretically the single ranked memory module will give slightly beter performance over dual ranked memory module. However dual channel memory is something else. In dual channel memory we are using for example a kit of 2 modules each having capacity of 4GB. In single channel mode we are using 8GB single memory module. Dual channel mode theoretically doubles the RAM access bandwidth on the computer, and therefore gives much higher performance (and yes, more FPS). This may be clearly seen in the test I've have given a link to it.
Leon
I always assumed and was under the impression dual channel memory only worked/benefited in combination with Hyper-Threading, the Celeron Processor J3455 in NUC6CAYH doesn't support Hyper-Threading as far as I know
Dual channel RAM operation and Hyperthreading are independent of each other.
You may enable either one without the other. So is not important that Celeron CPU doesn't support Hyperthreading to use Double Channel Memory mode. The Celeron J3455 Memory Controller has Bandwidth (single) 19,200 MB/s and for Double Mode has Bandwidth 38400 MB/s
Leon
Yes, NUC support dual channel memory configuration. And yes, in graphics games you can get very big improvement in computer performance. You can read the following article, dealing with this subject: http://nucblog.net/2015/09/dual-channel-vs-single-channel-does-it-matter/ Dual-channel vs. Single-channel, does it matter? – The NUC Blog .
Leon
