Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
NUC6CAYH vulnerable SA-00086
The Intel NUC6CAYH NUC is vulnerable to SA-00086 with the Trusted Execution Engine the Intel tool reports, when can we expect a update on this?
n_scott_pearson
Super User Retired Employee
If you have BIOS 42 or later installed, the updated Trusted Execution Engine Firmware, version 3.1.50.2222, which addresses INTEL-SA-00086, will be installed.
I see from your capture that this is the version of the Trusted Execution Engine Firmware that is on your system. Intel Customer Support will have to explain why the detection tool is still saying that the engine is vulnerable. I sure hope it is the tool and not the firmware...
Community Manager
My BIOS is 0045, so it is Trusted Execution Engine Firmware, version 3.1.50.2222
Hope it is a detection error like you said..
Community Manager
Today i discovered the SA-00086 tool got updated, it reports; "This system is not vulnerable. It has already been patched"
Only now it complains about the Intel Capability Licensing Service Client being obsolete!
Similar as these:
NUC6CAYH doesn't have Management Engine Driver. is it?
Community Manager
Any update about the "Intel Capability Licensing Service Client is obsolete" message on the NUC6CAYH?
Is there anything I need to install or is this a message that is not applicable to this model?
Community Manager
Hello, RVdH.
In this case, I will highly recommend you to perform a https://downloadmirror.intel.com/26802/eng/Chipset_Win10_10.1.1.35.zip Chipset updated. If this does not solve your issue please open a new thread regarding this issue explaining your problem. Make sure you include your system configuration and a clear explanation about the issue so we can give you a solution as soon as possible.
Antony S.
Community Manager
Installed Chipset INF driver version already is v10.1.1.35
I think the SA-00086 detection tool falsely reports the message about "Intel Capability Licensing Service Client is obsolete" as there is no MEI driver for the Intel NUC6CAYH so there is no way i can install a updated Capability Licensing Service Client
The "Intel Capability Licensing Service" simply doesn't exist on the NUC6CAYH if i open services.msc and list the services
