Intel® NUCs
12097 Discussions
NUC6CAYH with removed WIFI card from socket
MHand1
Are there any other uses for the installed card 3168NGW socket on this board?
I can use a dongle for wifi/bt.
Is the socket standard with other NUCs?
AlHill
It is an M.2 2230 slot for the AC-3168 slot.
https://www.intel.com/content/dam/support/us/en/documents/mini-pcs/nuc-kits/NUC6CAYS_NUC6CAYH_TechPr...
Other wireless cards have been validated as documented below:
http://compatibleproducts.intel.com/ProductDetails?EPMID=95062
Doc
MHand1
So the socket is only suitable for the same type item.
No storage drive or anything else?
Thanks​
n_scott_pearson
Super User Retired Employee
No, it cannot be used for storage. This M.2 socket is of type A/E and storage devices require a M.2 socket of type B/M. In theory it has two PCIe lanes and I suppose that, at least physically, it could host a slower x2 drive, but I do not believe that the BIOS is ready to support the NVMe steerage needed for this.
MHand1
Figured that was probably the case. Thank you for the prompt response.
