Community
cancel
Showing results for
Search instead for
Did you mean:
ATown3
NUC6CAYS 1 Blue Power Blink, Not Booting
My NUC6CAYS is only blinking its blue power LED once and not booting.
This was post updating BIOS AYAPLCEL.86A via the W10 executable.
I referred to the Blink Codes, but 1 Blue Blink and then no response is not listed: https://www.intel.com.au/content/www/au/en/support/boards-and-kits/intel-nuc-boards/000005854.html Blink Codes and Beep Codes for Intel® NUC
I referred to the BIOS Recovery procedure listed here: https://www.intel.com.au/content/www/au/en/support/boards-and-kits/000005532.html BIOS Recovery Update Instructions for Intel® NUC
I placed AY0040.bio (verified the MD5 of the download) on a FAT32 USB 2.0 drive in the front and back ports of the device, with a keyboard plugged in, and tried both VGA and HDMI display cables. I left the unit unplugged for a couple of minutes, plugged in the power and pressed the power on button again - just 1 blue blink, then nothing. No repeated blinks.
I removed the BIOS security jumper and tried the process again, same result. No boot.
Replaced the stock 2GB ADATA memory module with a known working Kingston 4GB module, same issue.
Why does the device have a single Blink mode thats not listed in the support documents?
Unable to call customer support at the moment, they are closed.
Community Manager
Hello NUC76,
Thank you for contacting Intel Communities.
I have sent you a private message.
Juan V.
Community Manager
Hi NUC76,
Juan V.
MBili1
Hello Dears,
I have exact problem with my intel nuc. What is the problem and if there is any solution?
BR
Martynas
