Community
cancel
Showing results for
Search instead for
Did you mean:
WP3
NUC6I7KYK UEFI install
I was trying to do a clean install of Windows 10 on my nuc6i7kyk.
At first, I plug in my win10 USB stick, when I press F10 to select it as a boot device, I cannot find this usb stick, when i press f2 to enter bios, I cannot find this usb stick either. I tried different USB stick; tried different ways of building the USB stick; tried different USB ports; tried to update the BIOS (from 0045 to 0055) and try to press f9 to load default setup in bios, found nothing.
Then what i can do now ?
n_scott_pearson
Super User Retired Employee
Try rebuilding your USB stick using Rufus. Make sure you select GPT partitioning and point to your Windows installation ISO.
Hope this helps,
WP3
Of course my USB stick created by Rufus as you said, but nothing happened on my nuc6i7kyk.
n_scott_pearson
What USB flash disks did you try (part numbers please)?
You want to do UEFI install, so UEFI has to be enabled. Have you tried with both Legacy enabled and Legacy disabled? You don't have Secure Boot enabled do you?
