Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
NUC6i3SYH Wake on LAN with USB power
Hello. I have NUC6i3SYH, with a bios bug.
For some reason, when i turn off Wake on LAN option, USB S4/S5 Power and Wake on USB from S5 refuses to work.
Can you fix that, so "Wake on LAN" would not interfere with USB power/wake on all NUC's?
Thank you.
My settings are:
1. Fast boot in Windows - Off.
2. Power Sense - On.
3. Deep S4/S5 - Off.
4. Wake From S3 via CIR - On.
5. Wake from S4 and S5 via CIR - On.
6. USB S4/S5 Power - On.
7. Wake on USB from S5 - On.
8. Wake on LAN from S4/S5 - Stay Off.
Note: If Wake on LAN is - "Power On - Normal boot", USB power/wake starts to work.
Highlighted
Super User Retired Employee
Have you installed the latest available BIOS (SY0060)?
Highlighted
Community Manager
Thank you very much to N.Scott.Pearson for the suggestion above.
Hi, akahack: Thank you very much for joining the Intel® NUC communities.
Please try a BIOS update using the F7 method, on the link below you will find the instructions of how to do that and the .BIO file needed for version 0060:
http://www.intel.com/content/www/us/en/support/boards-and-kits/000005850.html http://www.intel.com/content/www/us/en/support/boards-and-kits/000005850.html
https://downloadcenter.intel.com/download/26731/BIOS-Update-SYSKLi35-86A-?product=89189 https://downloadcenter.intel.com/download/26731/BIOS-Update-SYSKLi35-86A-?product=89189
Please let me know the results of trying the update.
Any further questions, please let me know.
Alberto R
Highlighted
Hello.
Yes, i've installed the latest bios and it has the same bug.
Highlighted
Community Manager
Thank you very much for letting us know that information.
akahack: In that case, I will do further research on this matter in order to try to find a possible solution for this problem.
As soon as I get any results, I will post all that information on this thread.
Alberto R
Highlighted
Community Manager
akahack: I just wanted to let you know that I just got an update on this matter and I just sent you an email.
Alberto R
Highlighted
Hello, thank you for support.
Will test new firmware after 2 weeks vacation.
Highlighted
Community Manager
Hi akahack: You are welcome. Perfect, no problem at all. Please let us know the results once you get the chance.
Alberto R
Highlighted
Community Manager
akahack: I just wanted to check if you were able to test the new firmware and if you need further assistance on this matter?
Alberto R
Highlighted
Hello Alberto!
Will check that till the end of this week!
Thanks!
Highlighted
Community Manager
akahack: You are welcome. Perfect, thank you very much for letting us know that information.
Alberto R
Highlighted
Community Manager
akahack: I just wanted to confirm if you have any updates about the installation of the new firmware?
Alberto R
Highlighted
Hey Alberto!
Sorry for a late reply, could you resend me BIOS? Thanks.
Highlighted
Community Manager
akahack: No problem, sure, please check your email.
Alberto R
Highlighted
Hello Alberto!
Finally tested it.
Wake from USB now works well without Wake on Lan.
Also, in my opinion, 7061 bios interface is more faster than older one.
Highlighted
Community Manager
Hi akahack: Thank you very much for letting us know that information.
Perfect, it is great to hear that it is working fine now and that the BIOS performance is better. We really appreciate your feedback.
Alberto R
Highlighted
Hello Alberto,
I have the same Problem and I am not able to fix it.
Can you send me the same BIOS File?
Niels
Highlighted
Community Manager
NielsR: Thank you very much for joining the Intel® NUC communities.
I sent you a private message, please check your inbox.
Alberto R
